Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 6 of 20 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 195
Thread: Motovox Doodle
  1. #51
    Member mrtheandrew's Avatar
    Join Date
    May 2012
    Location
    Olympia, WA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    ive got the mbx11, and am in the middle of pulling the stock motor to throw a 212cc in there. just waiting on some parts to come in the mail (clutch, chain cover, etc). ill be using a uni filter and aftermarket pipe, so it should fit beautifully in there.
  2. #52
    Senior Member TomH's Avatar
    Join Date
    Jun 2010
    Location
    close to Tulsa
    Posts
    3,493
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yeah brief summation of the posts leaving the drama out. Motovox rep was on here, they have a new model, MBX-11 with a bigger engine, front shocks, under the seat exhaust pipe adjustable handlebars and, read this..."targeted at the first time mini bike rider." There is a member here that has bought one and is putting the 212 predator on it. I hope he documents the re-motor.
  3. #53
    Join Date
    Jun 2010
    Location
    close to Tulsa
    Posts
    3,493
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Erok000 View Post
    I wonder if we could take those sprung forks and stick em on a DB?? Are they for sale seperatly?
    Back on thread #42 the Motovox rep was talking about selling a rolling chasis. Maybe you can get the front end? If we have someone chime in with some measurements from a new one, that might be a bolt on.
  4. #54
    Senior Member Erok000's Avatar
    Join Date
    Jul 2010
    Location
    Ravenna,Ohio
    Posts
    857
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by TomH View Post
    Ya I was hoping the rep wouldve chimed in with a reply for all to see. I Also PMd the rep and have gotten no response. Maybe some measurements WOULD help us to know better Thats if they are available seperate
  5. #55
    Join Date
    May 2012
    Location
    Olympia, WA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    i think this is the thread you are referring to. that is the mbx10. i have the newer mbx11, and will be putting the same 212cc motor in and will document the re-motor. i am not sure about the bigger motor that is supposed to be stock with the mbx11, as mine has the same 2.5hp that the mbx10 has.
    i should hopefully get to the motor swap this week as long as my parts arrive soon.
  6. #56
    Join Date
    Jun 2010
    Location
    close to Tulsa
    Posts
    3,493
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by mrtheandrew View Post
    Good deal. It was you I was talking about. Does your bike have the shocks on the front end and the under seat exhaust pipe? If it has, a few of us were wondering what the distance was on your fork tube from top to bottom. Might be able to retrofit the shock type front end onto the old stye DB30's. Interested in a pic of the exhaust pipe too and of course, the motor swap. I heard the frame is a little larger. Hope it is, tight squeeze with the MBX10.
  7. #57
    Join Date
    May 2012
    Location
    Olympia, WA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yes, it has the shocks in front and underseat exhaust. I'm out of town right now, but I should be home by Tuesday. I can take some measurements and pictures for you db30 folks then.
    I did take some measurements of the 212cc and the empty space it is going into in the frame, and it looks like it will fit easier than on the mbx10. I can't say for sure, but it definitely measured like it would fit right in. I have the installation plate, clutch, and clutch cover on order from ProMod. I was going to just bolt it right to the stock mount on the frame, but I want the adjustable slots that the promod plate gives you.
    I'll be putting a Uni filter and new jet in, and then adapting the predator exhaust to the stock underseat pipe. once ARC releases their billet flywheel that russell at NR racing says is on the way, then its governor removal, billet rod, cam, and valve springs. the stock pipe on the bike is a larger diameter than even the predators stock exhaust, so even though its around 2 feet long, it should flow fine. im keeping the stock exhaust because it looks sweet and sounds good even with the 2.5hp
  8. #58
    Join Date
    Jun 2010
    Location
    close to Tulsa
    Posts
    3,493
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I don't think the bolt pattern is the same unless they changed something, you either have to build your own slots or buy the adj. plate. Alright! I was wondering about the pipe, is the muffler built into the pipe?
  9. #59
    Join Date
    May 2012
    Location
    Olympia, WA
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    the bolt pattern for the 2.5hp and predator are different by about 1/4" or so, which is partly why i picked up the adapter plate. If i remember correctly, the muffler is removable at the end, held on by a clamp. even though it is the same bike, mine looks slightly different than this:
    i am not sure why it looks slightly different, as i also purchased it at costco, about 3 weeks ago. i cannot find a picture of mine anywhere online right now. maybe i have a newer style than what is shown on their website. same concept though, underseat and center exit. in the link i posted earlier to the thread where a member put a predator in his mbx10, you'll see that he didn't lengthen the chain, which is what caused the modifications to the exhaust and air cleaner. ill be looking to put as much chain as i need to get the motor to sit nicely in the frame. my main goal is to not have to move the rear fender back.
    edit: i did find one picture that barely shows the end of the exhaust style i have.
    http://eugene.craigslist.org/mcy/3016215008.html
    maybe motovox can explain the difference in styles.
  10. #60
    ProMod's Avatar
    Join Date
    Nov 2008
    Posts
    367
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Picked up one of the new style MBX11's this past weekend , They just recently became available in our area. We will be looking the new bike over and test fitting some of our products this week.
    I will take some pics and try to help out with some more info as well.
Similar Threads
  1. Doodle Bug
    By sourceminer in forum Projects & Rides
    Last Post: 03-12-2012, 11:16 AM
  2. help please - 6.5 on my doodle die when--
    By sundries in forum Baja Mini Bikes
    Last Post: 03-11-2011, 11:55 PM
  3. "Doodle Rat" Build (oh no not another 6.5 doodle...)
    By lzrider90 in forum Projects & Rides
    Last Post: 12-31-2010, 10:22 PM
  4. My $80.00 doodle bug
    By glenn baine in forum Baja Mini Bikes
    Last Post: 04-30-2010, 11:34 PM
  5. doodle bug?
    By gbones in forum Baja Mini Bikes
    Last Post: 10-08-2008, 09:09 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
