Register FAQ Members List Calendar Mini Bike Parts Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > General MiniBike Talk > Baja Motorsports - Doodlebug MiniBikes
Baja Motorsports - Doodlebug MiniBikes Baja Motorsports - Please put all Doodlebug questions in here!
Reply
Thread Tools Display Modes
Old 07-07-2008, 01:01 AM   #1 (permalink)
Member
doodlebug baja 97cc power..what the ....
No power!!!! it cant move my son and forget about me..Am i missing somthing?
we bought 2 today and both take over 2 minutes to get to speed..forget about any hills..i had to push it under power to go up the cauldasac.
Does everyone just toss them out?
speedbob is offline   Reply With Quote
Old 07-07-2008, 01:18 AM   #2 (permalink)
rudedog's Avatar
pulled off the 2.8 and replaced them with a 7hp robin/subauru on 2 of ours, and the third we left stock so far. it pulls my 80# son around just fine
rudedog is offline   Reply With Quote
Old 07-07-2008, 11:17 AM   #3 (permalink)
Senior Member
smallbikes88's Avatar
it is only 2 horse power. but check to see if the choke is still on, mabey thats the problem
smallbikes88 is offline   Reply With Quote
Old 07-07-2008, 11:25 AM   #4 (permalink)
Senior Member
delray's Avatar
check and see if your speed control screw is adjusted correct. you can make that little engine work good,but it will need to be regeared too. if the bike is for you son?keep the 2.5hp on. for you,install a 5.5 or 6.5
delray is online now   Reply With Quote
Old 07-07-2008, 12:30 PM   #5 (permalink)
Senior Member
i took the govener off mine it made hills better but it still took a good 5 minutes to get up to 31 mph.
hayden is offline   Reply With Quote
Old 07-07-2008, 12:33 PM   #6 (permalink)
Senior Member
Get a larger back sprocket.
superior is offline   Reply With Quote
Old 07-07-2008, 03:31 PM   #7 (permalink)
jim fallon's Avatar
i have a 2.8 on my sons it was slow at first just back out the speed control screw almost all the way and make sure the chain is not to tight that to will slow down the mini there not the fastest thing but it is great for kids and plenty fast enough for a 7o,80 # kid
jim fallon is offline   Reply With Quote
Old 07-07-2008, 06:28 PM   #8 (permalink)
Member
Put a 80 tooth rear sprocket on it. you will be amazed at how well that works.
rasndas is offline   Reply With Quote
Old 07-08-2008, 01:07 AM   #9 (permalink)
den35's Avatar
The big issue I've found with the DB30's stock setup is that the clutch seems to engage well before the engine hits optimal power rpm.I put a 5.5hp clone with a Maxtorque clutch on mine and it was a world of difference.
Easiest trick is a bigger driven sprocket,as previously stated.But you'll have to get one with no mounting holes and drill them yourself,as sofar no-one makes a larger sprocket for the DB30 yet.
Another idea would be to change the clutch with one that engages at higher rpm.
__________________
Keep the wheels on the bottom.
den35 is offline   Reply With Quote
Old 07-08-2008, 03:06 AM   #10 (permalink)
Member
Thanks for all the info.The chain was really tight.It helped a bit.
We put a tec 3.5 and a max torque clutch on the other already..wow 35mph easy..Thats not much power diff but it runs like it should.Something must be wrong.
The choke is not on.
I don't know how to adjust the speed control screw Jim..Could you tell me where that is at and what it looks like?
If i change the clutch will that really help or will i be spending money for not much gain?
Here would i get a undrilled gear at?Can i just get one with holes drilled and just make new ones ?
Also i don't think i should remove the govenor with a 10 and 13yo ridding..That's probably not safe is it?
Also one of the boys weigh in at around 120# and the other at 80# if that helps.
Reply
Lower Navigation
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0 RC2 Copyright 2006-2009 OldMiniBikes.com / OMB Group LLC
no new posts
