Results 1 to 7 of 7
  1. #1
    Senior Member markus's Avatar
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    8,901
    Rides
    non tank mounts carbs to fit 5hp briggs?
    What carbs do I need to look for for a 5hp briggs if I want to do away with the built on gastank? And are they cheap! Since thos motor does not hav e alighting coild and bike should have one I don't wnat to spen alot on the motor, I'll just search out a tec or something. don't need anythign fancy just want to utilize the gastank. Of course I could mount a spigot and use it to dispence beverage
  2. #2
    Senior Member miked's Avatar
    Join Date
    Nov 2008
    Location
    wyandotte michigan
    Posts
    529
    Rides
    go with an updraft carb
  3. #3
    Hello
    Join Date
    Jul 2007
    Location
    Deep East Texas
    Posts
    4,011
    Rides
    A 20mm Chinese clone of a Keihin with a 89 main jet will work great. Check 20mm carb and 20mm carburetor on ebay. One of the sellers lists the specs, including main jet size.You have to make or find an intake. The one I put on the Sears mini I'm starting is a vertical tecumseh intake of some kind. I matched it to my ports, but it was close. I think it came from a 4.75-6.5hp vertical tecumseh. It raises the carb and puts a 90 in it so it points out to the side.
  4. #4
    Senior Member
    Join Date
    Oct 2008
    Location
    California
    Posts
    2,498
    Rides
    Here's my motor with a Tillotson. Eventually I will have a foam racing filter setup.
    Tillotson intakes run $35-$40, and Carbs are cheap on ebay if you are patient.
  5. #5
    I still love that sandwich container air filter...lol
  6. #6
    Senior Member
    Join Date
    Oct 2008
    Location
    California
    Posts
    2,498
    Rides
    Well, I'm glad to see you aren't losing your memory.
    The sad thing is, I might be losing mine.
  7. #7
    Join Date
    Apr 2008
    Location
    Southwest Florida
    Posts
    8,901
    Rides
    Thanks guys, I'll keep my eyes open for somthing, "5 Horse" nice usage of the tupperware. I used to use them for radio boxes in my R/C race boats to keep the servo's and transmitter etc.. dry. They worked pretty good
Similar Threads
  1. Replies: 0
    Last Post: 10-21-2010, 09:40 PM
  2. Mods For Briggs Carbs?
    By Ibanez616 in forum Briggs & Stratton Engines
    Last Post: 09-30-2010, 02:28 PM
  3. 1969 rupp roadster need gas tank mounts
    By spendinit in forum Mini Bikes & Parts WANTED
    Last Post: 09-15-2010, 10:35 AM
  4. Replies: 0
    Last Post: 10-12-2009, 07:50 PM
  5. tillotson carbs on 5 HP briggs
    By cncd11 in forum Briggs & Stratton Engines
    Last Post: 09-02-2009, 11:25 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
