Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Member socket44052's Avatar
    Join Date
    Dec 2010
    Location
    Lorain,Ohio
    Posts
    71
    Rides
    model 14 year???
    Anyone know what year this is, model 143302, type 502525, serial 24874. I think it is 5.5 or 6hp but ID sheet list serial # instead of code.
  2. #2
    Richard Trotter's Avatar
    Join Date
    Jun 2008
    Location
    Spanish Fork,Utah
    Posts
    1,882
    Rides
    That is an oldie! If your serial number is correct, that is a 1948 model 14. That is the first year they were made. It was made in July or August and the first one was made in March. They were first listed as 5hp. Later the listing was changed to 5 1/2, then 5 3/4 and finally 6hp. The 6hp model 14 was discontinued in 1966. They are a real challenge to find parts for, but searspartsdirect can still find parts.
  3. #3
    Join Date
    Dec 2010
    Location
    Lorain,Ohio
    Posts
    71
    Rides
    model 14 engine
    Thanks, I was not finding much on this. It ran when I got it and will go again!
  4. #4
    Join Date
    Jun 2008
    Location
    Spanish Fork,Utah
    Posts
    1,882
    Rides
    For some reason, the model 14 doesn't show up in the repair manuals. Both 'Haynes' and my briggs manuals don't show the model 14. You can find most of the information in the model 17 section with only different bores. This makes the head, head gasket, rings and piston different. All the rest is the same( clearances, gaskets, crank, cam and valves). The seals may be different, so order those using your original model number.
  5. #5
    Join Date
    Dec 2010
    Location
    Lorain,Ohio
    Posts
    71
    Rides
    Thanks for the input, only way I knew it was a 14 was from Utube vid. my books do not list the 14 at all. Only problem with the motor is it has a 1" output shaft so I will need to find another crank or spring for a clutch.
  6. #6
    Senior Member 65ShelbyClone's Avatar
    Join Date
    Mar 2007
    Location
    Antelope Valley, SoCal.
    Posts
    2,440
    Rides
    If the crank is solid on the PTO side like my model 14's was, it can be turned down to 3/4" and cut for a new keyway.
    Have any photos of it? Those old long-stroke engines are pretty cool.
  7. #7
    Join Date
    Jun 2008
    Location
    Spanish Fork,Utah
    Posts
    1,882
    Rides
    The best way to identify a model 14 if you don't have the ID tag, is by the head. The 14 only has 8 head bolts. The 7hp and 8hp are the same size block but have 9 head bolts.
  8. #8
    Join Date
    Mar 2007
    Location
    Posts
    2,440
    Rides
    My 14 has seven head bolts.
  9. #9
    Join Date
    Dec 2010
    Location
    Lorain,Ohio
    Posts
    71
    Rides
    pics of engine
    here you go, this was a freebe so its just a plaything right now. Nothing like making them run!
  10. #10
    Join Date
    Jun 2008
    Location
    Spanish Fork,Utah
    Posts
    1,882
    Rides
    The number plates can be changed or lost, but that looks like an old motor with 4 coil mounting bolts. It looks like it is aluminium. 65shelby's motor is the correct early castiron model 14 with 7 head bolts. I found out it was '53 when briggs started making the aluminum motors. Look at the 'Iron Block motors' section to see 65shelby's motor.
Similar Threads
  1. Make,Model & year???
    By midwestkustomz in forum What is it?
    Last Post: 02-20-2011, 04:46 PM
  2. Anyone know the year, make and model ?
    By Hurley1982 in forum What is it?
    Last Post: 04-11-2010, 11:28 AM
  3. Anyone know this model/year?
    By gabe in forum What is it?
    Last Post: 02-24-2010, 10:11 PM
  4. year model id
    By Richard W. in forum Tecumseh Engines
    Last Post: 01-28-2010, 08:48 AM
  5. What Year and model FOX is this one??
    By antiquemotorcycle in forum General MiniBike Talk
    Last Post: 06-28-2007, 05:17 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
