Results 1 to 5 of 5
Thread: Gas Cap leak
  1. #1
    Member
    Join Date
    Jan 2012
    Location
    michigan
    Posts
    Rides
    Gas Cap leak
    I have two Briggs and Stratton engines (91202 model) with the plastic cap. Both of them leak from around the rubber seal on the cap. I tried a new cap and it still leaks. For my first one I used gasket maker suitable for gas and made another gasket, and put it between the rubber gasket and the cap. This works somewhat but not perfect. Do any of you have any ideas as to why these motors leak from the cap(is this a common thing with these engines) and how to solve this problem? I searched around the site and could not find anything specific for these motors.
    Thanks
  2. #2
    Member
    Join Date
    Jan 2012
    Location
    michigan
    Posts
    Rides
    Thanks miniwood, it doesn't make sense as to why it takes several caps that are all the same. Also one of these tanks is rusty, I searched the forum and read that evaporust is good at eating away the rust, but what do you guys do after you clean it so it doesn't come back?
  3. #3
    Senior Member
    Join Date
    Feb 2012
    Location
    Louisiana
    Posts
    333
    Rides
    Can you take pictures? My old honda clone leaked from under the gas cap. It wasn't much, so I just didn't worry about it. Does it leak only when the tank is full? Also, the best way to keep rust off the tank is paint. You can do it really cheap with a can of rustoleum. As long as water doesn't get in the tank, and the outside is painted, you are fine.
  4. #4
    Member
    Join Date
    Jan 2012
    Location
    michigan
    Posts
    Rides
    It leaks at any level of gas when it splashes around in the tank. I can't take pictures at the moment but it looks completely normal. I will try to take some pictures later if I can. About the inside of the tank: I cleaned the inside from rust and a few weeks later the bottom of the tanks looks to have the color of rust on it. Is this something to worry about? Should I put a tank sealer on my other tank before using it after removing rust? Sorry for all the questions.
  5. #5
    Senior Member
    Join Date
    Apr 2012
    Location
    Georgia
    Posts
    380
    Rides
    Quote Originally Posted by motorhead57 View Post
    Rust Remover - RustBlast - Metal Prep Primer - Metal Etch Don't know if that was exactly it but same type of product. will take a pic of the bottle later. Worked great on one of my tank after you found a way to scrape the rust all off the sides. Made it gummy. But let me scrape it out very easily. And the product I have is reusable if its a light job, not sure if this stuff is. But the coating it leaves behind inhibits rust from reforming on the bare metal.
    Shouldn't be a problem unless it starts fowling up your carb. On the other hand I cant imagine rust anywhere is good.
Similar Threads
  1. Oil Leak
    By tnorth in forum General MiniBike Talk
    Last Post: 04-04-2011, 01:21 PM
  2. Oil Leak
    By Mymini in forum Doodlebug MiniBikes
    Last Post: 01-29-2011, 11:18 PM
  3. '59 B&S Oil leak from fill cap
    By Squirrel in forum General MiniBike Talk
    Last Post: 07-07-2010, 10:36 PM
  4. Tec oil leak
    By Wigg273 in forum Engines and Modifications
    Last Post: 09-13-2008, 11:36 AM
  5. Leak Down Test
    By jumpjg in forum Engines and Modifications
    Last Post: 05-09-2007, 11:22 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
