Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Senior Member machinebike's Avatar
    Join Date
    Apr 2009
    Posts
    534
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Cut off 1inch crankshaft and modifying to a 3/4....
    I cut off the 1 inch shaft, left room to drill hole and tap with a 3/4 tap.
    I have a grade 8 3/4 bolt I mounted into it but when I turn the crankshaft, it is very, slightly crooked when i turn it.
    Any suggestions on how to get it straght after I already drilled and tapped?
    What about set screws to use to keep new shaft bolt from loosenig, would it work?
    Is there any reason this set up might not work? I drilled a 1/4 into the crankshaft that goes into the engine but not past where it rests on the bushing, should I be conserned with a balance problem?
    Thanks
  2. #2
    . Hent's Avatar
    Join Date
    May 2006
    Location
    South Eastern, PA
    Posts
    4,585
    Mentioned
    14 Post(s)
    Tagged
    0 Thread(s)
    Rides
    sounds like you need a new crank.
  3. #3
    Senior Member milo raptors's Avatar
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Hent View Post
    agreed....
  4. #4
    Member
    Join Date
    Dec 2008
    Location
    Clayton NC
    Posts
    69
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Tell us please???
    Why not turn the shaft down to 3/4 ???
  5. #5
    Banned Strigoi's Avatar
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,058
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by milo raptors View Post
    agreed....
    that. ....
  6. #6
    Banned
    Join Date
    Oct 2006
    Location
    Rockford, IL.
    Posts
    1,737
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by machinebike View Post
    Thanks
    How much did you cut off? Did you really use a 3/4" tap? If you cut off too much, and now the 3/4" (WOW!) bolt wobbles...you screwed up. LOL.
  7. #7
    Join Date
    Apr 2009
    Posts
    534
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Here are pics. looking closelt at the measure stick, you can see after turning engine, slightly off one part of turn. I did not turn enough to see correctly, its about half of one of those notches.
  8. #8
    Banned
    Join Date
    Oct 2006
    Location
    Rockford, IL.
    Posts
    1,737
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    What would be your next move, if the bolt was straight? What were you trying to accomplish?
  9. #9
    Join Date
    Apr 2009
    Posts
    534
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I was doing this to use a 3/4 centr. clutch.
    Next moves are to cut end of bolt off, drill and tap end and put groove in the bolt to hold clutch on.
    Its not crooked by much but enough to make it spin with a slight wobble.
  10. #10
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,058
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    buy a new crank.
    if you wanted it down to 3/4" the only real way to do it is to have the shaft turned down.
    that does not look safe at all. there's no way in hell i'd get on a bike with something like that done to it.
Similar Threads
  1. Need Help Modifying Clone
    By Hondagx160DB in forum Honda / Clone / Predator
    Last Post: 11-13-2010, 04:19 AM
  2. 1inch Tav2 Wanted
    By tomsprops in forum WANTED
    Last Post: 01-09-2010, 07:54 PM
  3. Modifying a 3.5 HP Briggs
    By Chopped50ford in forum Briggs & Stratton
    Last Post: 12-06-2009, 06:45 AM
  4. Wanted 1inch torque a verter
    By micro bill 7 in forum WANTED
    Last Post: 07-02-2009, 01:06 AM
  5. modifying an engine....
    By minibikes4life in forum Engines and Modifications
    Last Post: 12-16-2007, 03:12 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
