Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 10 of 10
  1. #1
    Senior Member MTchevy1's Avatar
    Join Date
    May 2010
    Location
    Villa Park, IL
    Posts
    245
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Need some magnetron conversion info
    I'm rebuilding an old briggs 5 horse, and I'd like to get rid of the points. What exactly do I need for the conversion? Will it still use my stock coil? I see the magnetrons for sale on ebay, but I'm not really sure what I'm looking for.
  2. #2
    Senior Member
    Join Date
    Oct 2008
    Location
    California
    Posts
    2,501
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You can buy either the converter unit or the Solid State Magneto.
    I think you should get the Magneto, because they tend to stop working after 15 years or so.
    I can't find the part number right now.
  3. #3
    Join Date
    May 2010
    Location
    Villa Park, IL
    Posts
    245
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    So the magneto is just basically a bolt-in swap? Does it use the same magnet on the flywheel to trigger it?
  4. #4
    Senior Member
    Join Date
    Oct 2008
    Location
    California
    Posts
    2,501
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yeah, it's just a swap.
    You need to make sure you buy the right coil though.
  5. #5
    Senior Member
    Join Date
    Oct 2008
    Location
    California
    Posts
    2,501
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If you can look up the coil for a 135232-0788 motor.
    It has the right coil.
  6. #6
    Join Date
    May 2010
    Location
    Villa Park, IL
    Posts
    245
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks a lot!
  7. #7
    125ccCrazy's Avatar
    Join Date
    Dec 2008
    Location
    toledo, ohio
    Posts
    6,116
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Rides
    this is the coil you want BRIGGS & STRATTON CRAFTSMAN 5HP IGNITION COIL # 397358 - eBay (item 320531694724 end time Jun-11-10 14:19:33 PDT)
    look around though as you may find one cheaper..
  8. #8
    Junior Member Ayers Garage's Avatar
    Join Date
    May 2010
    Location
    Springtown Texas
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I just converted mine a few days ago. The Magnetron kit comes in a little box with full instructions. It clips into place on the stock coil. You connect one wire and you're done. I just bead blasted my original coil and reused it with the kit, which cost 14 dollars at my local small engine parts house.
    Not having to ever worry about pulling the flywheel again down the road and fooling with the old points made the 14 dollars worth it to me.
  9. #9
    Senior Member
    Join Date
    Oct 2008
    Location
    California
    Posts
    2,501
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Ayers Garage View Post
    You should post up a part number for that !!!!!! Make it easier for us.
  10. #10
    Join Date
    May 2010
    Location
    Springtown Texas
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    part number 394970
Similar Threads
  1. Briggs 5hp Magnetron conversion kit 394970
    By 5 Horse Fan in forum Mini Bike Parts
    Last Post: 07-03-2010, 04:22 AM
  2. conversion 2.8hp to 9hp
    By gangway15 in forum Off Topic Discussion
    Last Post: 02-07-2009, 01:27 AM
  3. Replies: 0
    Last Post: 01-16-2009, 10:30 PM
  4. Replies: 0
    Last Post: 01-10-2009, 10:30 PM
  5. Conversion kit 6.5
    By ohman11 in forum Baja Mini Bikes
    Last Post: 10-13-2008, 08:17 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
