Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 7 1234567 LastLast
Results 1 to 10 of 69
  1. #1
    Member Wideopenthrottle's Avatar
    Join Date
    Dec 2011
    Location
    Sarnia
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    briggs 5hp supercharger ideas ?
    Well, i got thinking about briggs, more particuraly getting more power out of a small engine, what do you guys think about a SMOG pump hook the pully to a pully on the output shaft of the briggs, then a pipe ( rad hose ? [clamped] ) to the intake of the briggs then hooked up to the SMOG pump to act as a small supercharger ( it revs and forces air in the motor ) maybe like a 7 lb rad cap for a blow off incase the psi gets to high, what do u guys think . ?
  2. #2
    Tom S.'s Avatar
    Join Date
    Feb 2008
    Location
    Hillsboro, Ore.
    Posts
    4,930
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Others have tried it. Maybe you'll find some helpful info in these vids.
    http://www.facebook.com/NorthwestTrackShots
  3. #3
    Senior Member mr.modified's Avatar
    Join Date
    Dec 2010
    Location
    New Jersey
    Posts
    504
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I wouldn't worry about the pressure getting too high making something like you are talking about. If your using stock engine parts, making some kind of supercharger that would give you a pound or two would probably be good. I would get some type of gauge and hook it up to the intake so you can tell whats going on. Just don't try using a whole second engine as a supercharger like I have seen some people try on you tube, obviously there is going to be way more loss than gain. I was always going to make something up by welding up a centrifugal blower, maybe using some crank seals on the shaft. A roots type supercharger would be too tough to make up with just a welder and hand tools.
  4. #4
    Join Date
    Dec 2011
    Location
    Sarnia
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Well, im going to try to get 5lbs out of the 5 hp, :) i think it should get interesting i was reading up last night and someones head on a 5hp blew right off.
  5. #5
    Member
    Join Date
    Nov 2011
    Location
    lincoln
    Posts
    58
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Smog pumps are inefficient and will not supply shit for boost in a radiator hose. Maybe in a fuel line, but the smog idea is a joke and willnot work. If you want a belt driven supercharger get a small Turbo off an 80's Volvo and replace the ex. side with a pulley. Then run 112 race gas! Orrrr you could get a whippit bottle and nitrous cartridges and I think it could totally be possible to run spray on a small engine. Hotrod magazine put 4 leafblowers on a 84 vette and gained some HP. I bet an electric leafblower on a mini would provide a nice boost.
  6. #6
    Senior Member texasfabguy's Avatar
    Join Date
    May 2011
    Location
    Conroe,Texas
    Posts
    2,328
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    All of that has been done already.what you would spend on R&D you could buy a bigger motor and still go out to eat.
  7. #7
    Senior Member
    Join Date
    Jun 2010
    Location
    New Haven, Ct.
    Posts
    152
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    for some reason I cant see how a turbo built for a car that has roughly 120 hp, would ever work on a 5 hp...doesnt matter what you do to it.
    someone needs to man up and make a supercharger with a CNC machine
    thatd be sick to see a little briggs with a g-lader on the side
  8. #8
    Member
    Join Date
    Nov 2011
    Location
    lincoln
    Posts
    58
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Haha funny you say that because with the right pulley sizes and a blow off valve it will work.
    Sent from my SCH-M828C using Tapatalk
  9. #9
    Member dashben_01440's Avatar
    Join Date
    Oct 2011
    Location
    37876 TN
    Posts
    72
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    ive been wanting to do somthing like that for a while, i say try it, ive heard alot of good about the smog pump idea..
  10. #10
    Join Date
    May 2011
    Location
    Conroe,Texas
    Posts
    2,328
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    even at 100% increase that only 10hp.
    You are going to get a bunch telling you to just do it,of course they will have nothing vested in it. I'm all for trying new things but repeating someone else's mistakes is a sign of stupidity, fixing someone's mistakes is genius. research well before starting.
Similar Threads
  1. looking for briggs throttle cable/carb linkage ideas-
    By quiklids in forum Briggs & Stratton
    Last Post: 09-06-2014, 08:23 PM
  2. Supercharger?
    By germanauto1991 in forum Engines and Modifications
    Last Post: 07-04-2010, 03:27 PM
  3. any ideas? briggs
    By lloyd in forum Briggs & Stratton
    Last Post: 06-25-2010, 04:06 AM
  4. SuperCharger tank
    By supernova in forum Mini Bike Discussion
    Last Post: 05-20-2010, 12:58 AM
  5. Big Ass Supercharger
    By pete108 in forum Off Topic Discussion
    Last Post: 10-04-2007, 12:35 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
