Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Briggs & Stratton Engines
Reply
Thread Tools Display Modes
Old 11-28-2009, 04:41 PM   #1 (permalink)
Senior Member
hotroded's Avatar
no spark 3.5 briggs
ok here goes i have a 3.5 briggs motor used to be on a generator and it ran on my mini bike. but it sat for the winter and now it has spark when i put my finger in the wire and ground my finger wow what a jolt .
good spark there. when i put the plug on it and ground the plug no spark the plug is good i tested it on my tecumsh engine. i changed the coil or magneto
this engine has no points and condenser it has a alumininum piece on the flywheel .
there is a business card space between the mag and the flywheel.
and with the new coil i am still getting the spark to my finger but not to the plug . any ideas would be greatly appreciated .
hotroded is offline   Reply With Quote
Old 11-28-2009, 04:48 PM   #2 (permalink)
jeep2003's Avatar
test it with a screwdriver not your finger. If it can jump a small gap to the block it should be fine if your plug tested good. Make sure your connection to the plug is tight also
jeep2003 is offline   Reply With Quote
Old 11-28-2009, 05:43 PM   #3 (permalink)
Senior Member
milo raptors's Avatar
um dude points are behind the fly wheel
milo raptors is offline   Reply With Quote
Old 11-28-2009, 06:29 PM   #4 (permalink)
If it has wires running behind the flywheel, you have points and condensor. If it has a extra piece on the coil, and no wires running under the flywheel, you have a Magnetron,or Magnatron, whichever. Clean the ends of the coil that pickup the magnet on the flywheel, the magnet too wouldn't hurt. Try a new plug too. If you have points, clean or replace them and set them to .015.
jimh is offline   Reply With Quote
Old 11-28-2009, 07:20 PM   #5 (permalink)
Senior Member
Cyanide's Avatar
post pics of the engine
Cyanide is offline   Reply With Quote
Old 11-28-2009, 07:20 PM   #6 (permalink)
Senior Member
hotroded's Avatar
Quote:
yes the wires run off the magnatron there are no points and when u use a screw driver there is no spark unless you are like a hairs thickness away from the bolt to get spark.
the spark is blue also when it sparks across just no spark to the plug the plug is good i tested it on my other minibike engine.
this is just stumping the crap out of me the magnatron is new too.
thanks for the input
Old 11-28-2009, 07:23 PM   #7 (permalink)
bandit 40's Avatar
Hold on to it and give her a little pull. it cant hurt you, if it knocks you on your :censored: or raises the hair on your neck its good
bandit 40 is offline   Reply With Quote
Old 11-28-2009, 07:47 PM   #8 (permalink)
I'm not sure on Briggs , but Clintons had to jump a 5/32-3/16" gap to be considered good.
Yours is probably weak. If you have one on another engine, swap it and try it. I'm not sure you understood what I was saying. If you have wires running behind the flywheel, from the coil, you have points.
Old 11-28-2009, 08:16 PM   #9 (permalink)
Senior Member
hotroded's Avatar
i understood you the only wires running out are from the new coil or magneto that is on top of the flywheel .
one wire is bare that is grounded to the bolt where the coil mounts and the other comes out and mounts to the kill switch right.
i just took the new coil offand sanded the bottom of the new coil and the flywheel all the way around then where the coil mounted i sanded that too.
still no spark at the plug when its grounded ,but if i hold the coil wireand hold the engine i get a zap also when i hold it with a screw driver itit only will spark when i am a hair away but its blue I thought you used to be able to get a good spark to shoot from alittle distance like 3/16or better?
Old 11-28-2009, 08:23 PM   #10 (permalink)
jeep2003's Avatar
it really seems like the wire you said goes to the kill switch is the wire that would need to go to the points. That would make sense because it would still have spark just no points to give the energy any point of focus thus making it less intense. The kill switch should have its own wire to the same location on the condensor
Reply
Lower Navigation
Tags
briggs, spark
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
no spark on 5 hp scotln Briggs & Stratton Engines 7 08-15-2009 10:50 AM
no spark android Tecumseh Engines 4 07-01-2009 05:36 PM
no spark on my briggs HELP!!! mac350 Briggs & Stratton Engines 6 11-18-2008 08:13 PM
No spark on my 5HP Briggs!! INTHE10s Briggs & Stratton Engines 9 05-20-2008 01:41 AM
Briggs & Stratton Spark Tester drheilman Shop Tools 1 12-03-2007 09:49 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
