Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Briggs & Stratton Engines
mini bike parts
OMBWarehouse.com - Mini Bike Parts
Reply
Thread Tools Display Modes
Old 07-11-2010, 11:51 PM   #1 (permalink)
Senior Member
DreyeIce's Avatar
How do i run a light?
I did a briggs 5hp swap on my RUPP hustler, and right now, inbetween the upper forks, i have a #9 pitbike thing so it dosent look so bare,
i have a few spare baja KC lights from my offraders, and the smaller one i have, fits nice and can be mounted in-between the forks,
how do these motors run lights, and how would i wire mine with a switch from where on the motor, thanks,
i plan on maybe doing some night riding, and this would be sweet,
DreyeIce is offline   Reply With Quote
Old 07-12-2010, 12:22 AM   #2 (permalink)
wayne's Avatar
if your engine is not lited,some guys use small 12 volt drysell fastend to
mini somewere,out of site if you can,good luck,
wayne is offline   Reply With Quote
Old 07-12-2010, 10:15 AM   #3 (permalink)
Senior Member
cxbra's Avatar
Yeah, I would like to run a light w/ a mini 12v now that they're cheap enough. My ultimate setup would be a HID mountainbike light set ($160 though...). It has a super small battery that powers a true 2" HID light (bright as f***!) for about 4-6 hours. I was a bike mechanic for a few years and know whats real, that light is real!
I just couldnt justify spending that much on a light when I my 5hp Flathead needs some gaskets and a billet rod, but they are nice and durable and water resistant.
cxbra is offline   Reply With Quote
Old 07-12-2010, 11:57 AM   #4 (permalink)
Senior Member
DreyeIce's Avatar
so i cant install somthing to generate power for a light?
Old 07-12-2010, 03:51 PM   #5 (permalink)
Senior Member
cxbra's Avatar
I think you can install somethin as a generator, I think its called a stator. Its what comes on electric start engines, expensive and not worth it in my opinion unless you want to put on an electric $tarter.
Old 07-13-2010, 05:36 PM   #6 (permalink)
5 Horse Fan's Avatar
If a light is needed right away, just grab a flashlight and duct-tape.
There are flywheels with internal magnets and stators that bolt up to the block.
5 Horse Fan is offline   Reply With Quote
Old 07-13-2010, 10:07 PM   #7 (permalink)
Senior Member
DreyeIce's Avatar
thats what i was thinkin, get a flywheel with a mounted stator and but a rotor for underneath, wire it up nice, but u have a points motor, wouldent that interfere with the stator assembly? i dunno, but my motor was originally from a snowblower,
i think im gonna go with the 12 battery idea, i got the perfect place for it on the rupp, and i am gonna use a standard plug charger to charge it up, so its easy,, and i wont do TONS of night riding, just nice to have,
Old 07-13-2010, 10:36 PM   #8 (permalink)
Member
alex10's Avatar
What parts do I need to put a stator on my 5 horse? I have the magnetron ignition.
alex10 is offline   Reply With Quote
Old 07-13-2010, 11:55 PM   #9 (permalink)
Senior Member
correct block[later version].longer crank,stator for under flywheel,correct i/c military flywheel[thats where i found mine].these parts are tough to find,exept the crank shaft which is the same as the snowblower electric start crank.
the corect block will have 2 "stands" under the flywheel that will be drilled but most likely not threaded.
you will have about 5 amps at best to light with.
funky ole is offline   Reply With Quote
Old 07-14-2010, 12:29 AM   #10 (permalink)
Senior Member
DreyeIce's Avatar
why do i see rupps with stock HS40's running lights, is there a battery somwhere mounted?
Reply
Lower Navigation
Tags
light?
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
What is that light? ct77 General MiniBike Talk 2 11-26-2010 09:22 PM
1970 Rupp Roadster: Rear Light and Brake Light JDB General MiniBike Talk 2 07-19-2010 01:21 AM
light problems maddcarson More than two wheels. 15 04-30-2010 06:54 PM
i need light bigfishisback Doodlebug MiniBikes 33 01-31-2010 10:12 PM
Head light and tail light??? stubbysteve Off Topic Discussion 0 01-15-2008 01:41 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
