Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Briggs & Stratton Engines
Reply
Thread Tools Display Modes
Old 07-11-2012, 11:14 AM   #1 (permalink)
Senior Member
wildman's Avatar
Question Briggs 5hp throttle linkage
This has probably been answered many times on this forum, but I canít find it. Is there a standard practice for converting this type of old push/pull wire throttle linkage ↓ to typical braided cable and return spring?
Iíve done this conversion on the linear type linkage ↓ using the Briggs kit #692316, but not on the radial type.
Thanks for any help.
wildman is offline   Reply With Quote
Old 07-11-2012, 11:39 AM   #2 (permalink)
125ccCrazy's Avatar
this a top mount, it does away with the linkage on the bottom....no governor either... http://www.out2win.com/catalog/images/RR4452.jpg
__________________
in some cases it's only original once...in others, unrestored it's a piece of crap forever..
125ccCrazy is offline   Reply With Quote
Old 07-11-2012, 12:04 PM   #3 (permalink)
Senior Member
Any pics of that installed?
aarron is offline   Reply With Quote
Old 07-11-2012, 12:36 PM   #4 (permalink)
Senior Member
wildman's Avatar
Was hoping to keep the governor functioning. This there a p/n for that kit?
Thanks.
Old 07-11-2012, 12:38 PM   #5 (permalink)
buckeye's Avatar
Here ya go.
buckeye is online now   Reply With Quote
Old 07-11-2012, 12:45 PM   #6 (permalink)
Randy's Avatar
Not that it matters, I guess. But that compression fitting is on backwards.
Randy is offline   Reply With Quote
Old 07-11-2012, 12:52 PM   #7 (permalink)
buckeye's Avatar
Only pic I have. I used it for reference.
Old 07-11-2012, 12:58 PM   #8 (permalink)
bandit 40's Avatar
Rieken's Racing: Throttle Linkages - OUT2WIN.COM
Try this
__________________
If guns cause crime, all mine are defective. Ted Nugent
bandit 40 is offline   Reply With Quote
Old 07-11-2012, 02:11 PM   #9 (permalink)
creia's Avatar
The throttle kit posted by others works great and it is a very good value. We've used them on numerous engines (both 3 Hp and 5 HP) and been very satisfied. There is a "head's up", however, that you should be aware of if you are purchasing one of these:
1. The kit does NOT come with the small Briggs shoulder bolt that secures the bellcrank assembly to the carb (it assumes you already have one I guess). So you will need to purchase one- we got ours at a local mower shop and on Ebay.
2. The kit does NOT come with the short Briggs linkage/rod that connects from the bellcrank to the throttle plate. Again, you will either have to make one or purchase it separately.
3. You cannot use these kits with the governor linkage connected- it MUST be removed.
I thought members would like to know this ahead of time....
Michael
creia is offline   Reply With Quote
Old 07-11-2012, 02:42 PM   #10 (permalink)
buckeye's Avatar
Quote:
Originally Posted by bandit 40 View Post
thanks myself.
Reply
Lower Navigation
Tags
briggs, linkage, throttle
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
throttle linkage hook up briggs 3.5 ccobra70 Engines and Modifications 5 06-18-2012 05:42 PM
Briggs 5 HP I/C with updraft carb - throttle linkage help wanted dw1973 Briggs & Stratton Engines 0 01-28-2012 08:15 PM
8hp Briggs I/C Throttle linkage panman9 Briggs & Stratton Engines 17 10-08-2011 11:21 AM
Briggs Throttle Linkage.. ozark1 Briggs & Stratton Engines 2 11-10-2010 02:05 PM
Tecumseh Throttle Linkage, Briggs 5hp Flywheel Shroud 5 Horse Fan Mini Bike Parts 4 01-03-2009 06:44 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
