Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Doodlebug won't stay running
    I bought a baja doodlebug about a month ago and haven't had any problems until yesterday. It suddenly got very hard to start and when it does start, it will only idle for about 5 seconds and then shuts off. Any attempt to rev it during that 5 seconds results in it immediately shutting off. Since I know very little about small engine repair, I was wondering if anyone had any suggestions?
  2. #2
    Senior Member jim fallon's Avatar
    Join Date
    Oct 2007
    Location
    melbourne florida
    Posts
    517
    Rides
    check the carb , air filter somtimes the choke will stick take the carb off and spray carb cleaner in to it every little spot you can it could dirty in one of the jet holes . try it
  3. #3
    Banned Strigoi's Avatar
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,009
    Rides
    swap in a clone.
    like Jim said, start by cleaning out the carb. it doesn't take much to clog a jet.
  4. #4
    Senior Member Vaxian's Avatar
    Join Date
    Mar 2009
    Location
    Charlotte, NC
    Posts
    158
    Rides
    Lightbulb Can of carb cleaner good as gold!
    Get a can of carb cleaner with an extension tube, take out the carb adjustment screws and spray cleaner liberally inside until you see it coming out the inside of
    the carb.
    This usually does the trick 4 me.
    Also, if you have a fuel line, cut and install an inline filter. This will help with future carb problems.
    Good luck and happy puttering!!!
  5. #5
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,009
    Rides
    Quote Originally Posted by Vaxian View Post
    i've had a bunch of random crap show up in my filter. i'm glad it didn't make it into the carb/engine.
  6. #6
    Join Date
    Mar 2009
    Location
    Charlotte, NC
    Posts
    158
    Rides
    Oh Yea, it's surprising the amount of crud that ends up in your tank, all it takes is one tiny piece to end up in the carb and
    The most important things in my shop are my can of carb cleaner and a box of filters, they've both saved me a lot of frustration.
    One reason I dislike the carb/tank combos by B&S, no way to install a filter.
  7. #7
    Thanks for the help everyone. I'll get a can of carb cleaner this weekend and try it.
  8. #8
    Member Don's Avatar
    Join Date
    Apr 2007
    Location
    Massachusetts
    Posts
    61
    Rides
    Ours were doing the same thing. I tried everything and finally raised the idle speed just to the point that the bikes almost want to move on their own. That fixed them.
  9. #9
    Junior Member trudgen3@comcast.net's Avatar
    Join Date
    Jul 2007
    Location
    Vandergrift,PA
    Posts
    Rides
    i just got my db on thursday ($150 could not have more than 5hrs on it)it started rite up when i went to buy it. brought it home went to take it 4 a cruise now the wont even try to start. i tried to spray starter fluid in to it and nothing. ill try the taking the carb off next.
  10. #10
    Senior Member bucksboysdad's Avatar
    Join Date
    Mar 2009
    Location
    Ohio
    Posts
    154
    Rides
    trugen3, where did you get your DB for $150? I'm looking for a second one?
Similar Threads
  1. wont stay running
    By mac350 in forum Tecumseh Engines
    Last Post: 11-10-2010, 06:42 PM
  2. DB30 won't stay running (just out of the box)
    By phk1967 in forum Doodlebug MiniBikes
    Last Post: 08-27-2010, 11:12 PM
  3. Briggs 3 hp won't stay running!
    By OldBlue in forum Briggs & Stratton Engines
    Last Post: 10-20-2009, 05:15 AM
  4. 5 hp briggs wont stay running
    By oldphocker in forum Briggs & Stratton Engines
    Last Post: 10-10-2009, 09:34 PM
  5. Engine does not want to stay running
    By wasr10 in forum Doodlebug MiniBikes
    Last Post: 07-31-2009, 07:35 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
