Results 1 to 10 of 10
  1. #1
    Junior Member
    Join Date
    Oct 2008
    Location
    N.E. Orlando
    Posts
    Rides
    6.5 HP Honda Clone w/ Charge Coil found...
    here she is, for all of those than want lights with there 6.5 upgrade...
    Sterling Small Engine Warehouse
  2. #2
    Junior Member
    Join Date
    Oct 2008
    Location
    N.E. Orlando
    Posts
    Rides
    here's another, this one's from carroll stream...
    link
  3. #3
    Senior Member Sinner70's Avatar
    Join Date
    Jul 2008
    Location
    Cape Cod-MA
    Posts
    1,798
    Rides
    Quote Originally Posted by DJGypsy View Post
    link
    check out the 8hp for a little more $$$. electric start too.
  4. #4
    Senior Member fonz's Avatar
    Join Date
    Aug 2008
    Location
    MI
    Posts
    351
    Rides
    I believe the 8hp to 13hp Honda and their clones use a much bigger block. With the gas tank on they are 3 inches taller . The base plate is about an inch longer too with a different bolt hole pattern. cjtmini's base plate wouldn't work with 8hp and above models. They also use a one inch shaft.
  5. #5
    Join Date
    Jul 2008
    Location
    Cape Cod-MA
    Posts
    1,798
    Rides
    Quote Originally Posted by fonz View Post
    that sucks.
  6. #6
    Senior Member
    Join Date
    Nov 2008
    Location
    Central Massachusetts, Webster,Ma.
    Posts
    Rides
    I like that 2.5hp Carrol stream for my little girl! 9 years young 85lbs. What do you think? Both of those sites have nice engines!
    Together we stand - Divided we fall! Mini's forever!
  7. #7
    Join Date
    Aug 2008
    Location
    MI
    Posts
    351
    Rides
    Why swap engines then? The DB30 has about that size engine on it out of the box?
  8. #8
    Senior Member smallbikes88's Avatar
    Join Date
    Nov 2007
    Location
    garfield hts. ohio
    Posts
    3,676
    Rides
    sorry to inform you those engines do not have the lighting coil they are just electric start. You need a battery to start it and you can run a headlight off the battery but when the batttery dies no lights or start.
  9. #9
    Senior Member Motra's Avatar
    Join Date
    Mar 2008
    Location
    SLC, UT
    Posts
    1,920
    Rides
    Quote Originally Posted by smallbikes88 View Post
    The Sterling says in the specs that it has a 12 volt 8.3 amp charging system.
  10. #10
    Senior Member OldMinibiker's Avatar
    Join Date
    Aug 2008
    Location
    Ft.Wayne,IN
    Posts
    355
    Rides
    Dumb question,can one buy the coil and then just hook it up to their clone? Or is there way more to it than that? I noticed on the Sterling site the parts are out of stock too.
    Tim
Similar Threads
  1. Lighting Coil To Charge A Battery?
    By Ruppster81 in forum Engines and Modifications
    Last Post: 03-15-2011, 02:14 AM
  2. Replies: 0
    Last Post: 11-18-2009, 09:40 PM
  3. Big Block Tec Charge Coil & Flywheel $75 Del.
    By Randy in forum Mini Bike Parts
    Last Post: 11-04-2009, 02:57 PM
  4. Tec HS40 charge coil assy
    By markus in forum Mini Bike Parts
    Last Post: 09-15-2008, 06:31 PM
  5. Tec lighting/charge coil question
    By Randy in forum Engines and Modifications
    Last Post: 09-12-2008, 11:37 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
