Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Member
    Join Date
    May 2009
    Location
    Southeastern PA
    Posts
    39
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thumbs up Baja 2.8hp 97cc 4-stroke engine help
    Does anyone have any tips for my db30's power and acceleration?
  2. #2
    Banned Strigoi's Avatar
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,059
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    swap in a 6.5 clone. the stock motors don't put out enough power for an adult.
  3. #3
    Member
    Join Date
    May 2009
    Location
    Southeastern PA
    Posts
    39
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hello again
    Thanx strigoi u probably remember me better as happy2387, but this is my new account. If u remember I am a kid. only weigh 115lbs. How much would a 5-6.5 cost at a junk yard?
  4. #4
    Senior Member den35's Avatar
    Join Date
    Apr 2008
    Location
    Copper Cliff,Ontario, Canada
    Posts
    586
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If I may say so,why look at a junk yard?Brand new 5.5 or 6.5hp motors are quite inexpensive.Around $130,sometimes even less.
    Even a kid with a paper route can save up enough pennies for that.
  5. #5
    Senior Member
    Join Date
    Mar 2009
    Posts
    113
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If you know someone who can weld put a jack shaft kit on it, it makes a huge difference. Your gearing will be lower for quicker take off speed but your top speed will be less. If you also removed the Governor you could get the top speed back and have quicker acceleration. If you do put a new engine on it you have the cost of the engine, a new clutch and a mounting kit if you cant do the work yourself so it can add up pretty quick.
    Jordon
  6. #6
    Senior Member cxbra's Avatar
    Join Date
    Mar 2008
    Posts
    815
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    All you can really do is to make sure it is running 100% to its potential. There are no mods for this engine, though I have seen someone make an intake for it. You could try making an intake & exhaust, but thats about all I could think of to mod this motor. I dont think they can flow enough air to benifit from any carb upgrades, I think it runs kinda rich from the start. Heres my list of things ive done to maximize the stock engine potential.
    1. Carb tuning is the most important thing. I leaned mine all the way out and it was running like a beast but it was also pinging a little. Run it on the lean side, but listen for popping. If it does, add fuel 1/4 turn at a time.
    2. Use the right weight motor oil.
    3. Make sure the throttle is opening all the way.
    4. Make sure your brakes are not dragging too much. They have to "drag" a little for good braking responce though, but not enough to stop the wheel when spinning by hand.
  7. #7
    Junior Member
    Join Date
    Jun 2011
    Location
    Canada
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Would a honda GX 120 engine work in DB30? It seems to be similar in size and HP.
  8. #8
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,059
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    it won't just bolt in. you'll either need to drill/slot new holes or get one of the adapter plates. you also need to get a 3/4" clutch.
  9. #9
    Clayon's Avatar
    Join Date
    Apr 2010
    Location
    Saskatchewan, Canada
    Posts
    6,091
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Bajamini View Post
    Well my friend I have 5 simple steps to make your 97cc (2.8hp) engine move that little DB30.
    1. Weld up a header for it (I don't know if you can buy them or not).
    2. Build a ram air intake out of PVC that comes out by your leg by the recoil, I did it and it made a reasonable difference.
    3. Rejet the carb, get a set of numbered drill bits remove the idle jet and drill it out with the #77 bit. I did this an it worked good.
    4. On the stock carb there is a black plastic tab, break it off carefully and you will now have access to the mixture needle, adjust it accordingly.
    5. Set the gov arm springs to the highest up of the 3 holes, it will rev higher that way. (In the pic I show you do not drill the 4th or 5th hole, the pic is just for clearification on what spring to adjust.
    This will result in a moderate speed/acceleration increase, for better acceleration and torque check out the PMR jackshaft kit. My DB30 with the 97cc (2.8hp) engine went 32 to 34mph (on GPS) but I bypassed the governor, and you should not do that I ended up blowing my engine because of it, but it could've been worse, the connecting rod could've came through the seat. I know it is tempting to do, and results in more power, but don't unless you have the billet con. rod and flywheel which are not availible for this engine.
    OMB BROTHERHOOD
    OMB forever, forever OMB.
  10. #10
    Junior Member
    Join Date
    Dec 2014
    Location
    Longview
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I'm still wondering if I need to by a new carb for my baja racer. It seems like it's not getting enough fuel. Does anyone recommend buying a new carb for a possible fix to the massive lack of power I'm experiencing. And also what do you Recommend for a spark plug?
Similar Threads
  1. Baja Racer 97cc engine troubles
    By tjscarts in forum Mini Bike Discussion
    Last Post: 03-27-2010, 11:47 PM
  2. 2.5 hp baja db 97cc engine
    By colrhino in forum Baja Mini Bikes
    Last Post: 10-11-2009, 12:59 PM
  3. Baja DirtBug 97cc
    By Carden in forum Baja Mini Bikes
    Last Post: 05-16-2009, 04:40 PM
  4. Baja 97cc Engine with clutch $75obo you pay shipping
    By vette66_00 in forum Mini Bike Parts
    Last Post: 04-17-2009, 02:29 AM
  5. wtb 97cc baja parts
    By driftoy in forum WANTED
    Last Post: 02-13-2009, 11:13 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
