Results 1 to 2 of 2
  1. #1
    Junior Member
    Join Date
    Aug 2012
    Location
    Tazewell, Virginia
    Posts
    Rides
    Predator 212 cc low oil sensor
    Does anyone know where you disconnect the low oil sensor on a Predator 212cc engine? I have one on a buggy and it shuts off in curves, mainly when turning right very fast.
  2. #2
    Senior Member Dave_In_Florida's Avatar
    Join Date
    Aug 2009
    Location
    Tampa Florida
    Posts
    434
    Rides
    All it does is ground out the coil when the little float in the case gets low (such as in the curves). So look for the wire coming out of the front of the case and disconnect it from the wiring for your shut off switch. You can cut it but if you do and that wire touches anything metal it will shut the motor off.
Similar Threads
  1. low oil sensor
    By iatemeself in forum Engines and Modifications
    Last Post: 04-23-2012, 12:42 PM
  2. Oil sensor?
    By outdoorguy in forum Engines and Modifications
    Last Post: 03-30-2012, 09:07 AM
  3. Predator 212 low oil sensor & billet rod?
    By Bikerscum in forum Honda / Clone / Predator Engines
    Last Post: 01-22-2012, 08:24 PM
  4. need a oil sensor for a 5hp B&s
    By dirt bug boy km in forum Briggs & Stratton Engines
    Last Post: 12-02-2008, 02:49 PM
  5. low oil sensor
    By JustEnough in forum Honda / Clone / Predator Engines
    Last Post: 11-10-2008, 09:28 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
