Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: predator 60363
  1. #1
    Member
    Join Date
    May 2014
    Location
    nebraska
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    predator 60363
    Whats the difference on this engine 60363,and this engine 69730 from harbor freight. i ordered the 60363 engine hope i got the right one.
  2. #2
    chipper's Avatar
    Join Date
    Dec 2013
    Location
    Denham Springs , Louisiana
    Posts
    5,977
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Rides
    That is the Hemi , 3600 rpm . So if you want a Hemi you got the right one !
  3. #3
    Junior Member
    Join Date
    May 2014
    Location
    Lenoir, NC
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I think so
  4. #4
    Member
    Join Date
    May 2014
    Location
    nebraska
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Well i got the motor took governor off, built new linkage with cloths hanger then had no way to connect to the 1968 XL-500 rupp gas tank since it has super tiny fuel line on the predator. So my son wanted me to see if we could run it with factory tank. well guess what the motor sits too low and hits the jack shaft and also looks like i cannot get the clutch and the jack shaft to align even if it did not hit. does anyone make a plate or something to raise the engine high enough to make the darn thing work? It looks like i need the omb mini bike parts kit for air filter and exhaust so i can hopefully shove it up high enough to work. I gave him the bike for his birthday so he even helped work on the new motor until it wouldnt fit then he almost cried and i feel bad for him. So what do i need guys to get this thing on the roads again? please help
  5. #5
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,563
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Man thats bad Buck ! How high does it need to move up ?
    Lil Indian, Ruttman, DB30, Warrior, lil Bill, EZ Rider, Savage SSC , Powell
  6. #6
    Member
    Join Date
    May 2014
    Location
    nebraska
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    The higher the better that way if the chain comes off it don't hit the head. I need to strip off the air breather,gas tank,exhaust so i can try and stuff it up high enough to get some clearance ideas. I think 1 inch or so would work just figured someone on here would of already had a solution or a mounting plate that they sold so i also could get a better sprocket alignment and chain adjustment when mounted since the motor is a pig with factory parts. the 3.5 clinton that i had on it would not align properly either.
  7. #7
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,563
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    OK Buck , I'll do some checking for ya..I have not run into this problem yet. But maybe someone else has.
    As far as the gas hose goes, I usally shove a short piece of 3/16 clear fuel hose over the inlet on the carb and cut it off flush..then your 1/4 inch fuel hose will fit tight over it.
  8. #8
    Senior Member S1att3r's Avatar
    Join Date
    Jun 2012
    Location
    North East Texas
    Posts
    142
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Engine Mount for installing a GTC Torque Converter on Minibike Honda GX160 / GX200 K&N Performance Air Intake, Titan clone engines
    If you don't mind spending some money. I have one on my bike so I wouldn't have to modify my tav.
  9. #9
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,563
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Looks good S1att3r.
  10. #10
    Member
    Join Date
    May 2014
    Location
    nebraska
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Nice looks good 2 inches is a lot. I will have to start working on it again soon as i get a day and night off. Tonight i may stay up late and work on it u guys keep me going and spending money. LOL. Wish i could see a top view to know if i can get the sprocket alignment straight. the original engines must of had a lot longer crank end so the clutch could align better. Thanks im closing now going to start getting bench cleaned off.
Similar Threads
  1. 212cc Predator non hemi vs 420cc Predator
    By Sundance customs in forum Honda / Clone / Predator
    Last Post: 10-20-2014, 11:08 PM
  2. predator mod ???
    By Bam3hunnit in forum Honda / Clone / Predator
    Last Post: 06-25-2014, 11:06 AM
  3. New Hemi Predator Engine Take off parts, model 60363, So Cal
    By LSCustoms in forum Mini Bike Parts
    Last Post: 11-22-2013, 11:19 PM
  4. Baja with Predator can I use lighting coil pack on Predator?
    By JoePapa in forum Mini Bike Discussion
    Last Post: 12-01-2012, 04:16 PM
  5. im new with the predator plz help
    By predator bike in forum Honda / Clone / Predator
    Last Post: 06-10-2012, 11:18 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
