Register FAQ Members List Calendar Mini Bike Parts Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Thread Tools Display Modes
Old 03-13-2009, 01:18 PM   #1 (permalink)
Senior Member
65ShelbyClone's Avatar
The great big Electronic Fuel Injection thread!
Rather than take BraneDeadX's very cool project log off track with general EFI discussion or resurrect other old threads, I decided we could have a dedicated thread right here. Many people seem to be interested in fuel injection, but it is not generally a simple task. It requires some knowledge of electronics, computers, and internal combustion engine operation and theory.
This can be the new place to ask questions about all that. Anyone with answers to those questions is free to jump in and share so that we all might benefit.
So.....any questions?
__________________
"I got my feet in the sand, I got a house on the hill,
I got a headache like a mother, twice the price of my thrills."
65ShelbyClone is offline   Reply With Quote
Old 03-13-2009, 01:55 PM   #2 (permalink)
Senior Member
Stang's Avatar
I love all the EFI talk, I just wish I had the mechanical skills to fabricate all the stuff to play with one. I write powertrain software for an automotive supplier and it would be interesting to see what some things they do on cars/trucks would do on a small engine.
P.S. MargayKart needs to post more because his setup was probably one of the best I've seen! :D
__________________
Rupp TT500 - New Project!
Ruttman Spyder - GX200 Project
HPE Muskin CAT R4005
Ruttman 390
Clone Block, Head (-.100, port matched and short side radius work), ARP Studs
Rotating Assembly: Honda Crank/Piston (Flattop, Cryo treated), ARC Rod, Flywheel (30deg)
Valvetrain: CAM (NR 320 Grind), Stainless Valves, EES Springs, Aluminum Retainers/Locks, Chromoly Pushrods, 1.3 Billet Roller Rockers
Induction & Exhaust: AGK Billet Intake, Mikuni 34mm Flatslide & Fuel Pump, Cloth Filter, 1.5" Header
Stang is offline   Reply With Quote
Old 03-13-2009, 02:29 PM   #3 (permalink)
Senior Member
Oh yeah? What programming language(s) do you use most often? I have been pecking away very slowly at upgrading my MegaSquirt MAP sensor with a 700kpa part(highest the supported upgrades go is 400kpa), but it requires code changes to both the firmware and Megatune software and I'm not a programmer by any means. Kinda wingin' it.
Yeah, MargayKart79 has an awesome cool setup on his kart....turbocharged and injected for those unfamiliar.
__________________
Old 03-13-2009, 03:27 PM   #4 (permalink)
Senior Member
Stang's Avatar
We use C most of the time, but for the eTPU on the Freescale MPC55XX family we sometimes need to use assembler or what they call microinstruction set. The compilers that are out for it are complete trash.
Currently we are mostly doing projects for GM, Ford and Chrysler, not much import business. You name it we do it, direct and multiport injection, with solenoid and piezo injectors.
I specifically work on low level hardware drivers, not the application part that contains the actually algorithms, but I have been know to have a look here and there :)
I actually wanted to do an EFI briggs engine back in college 6 or so years back, but no one else was interested and it would be impossible for me to write all the software and fabricate anything in that amount of time.
I'd really just like to see where people are getting parts, scavenging from cars/motorcycles and what they are fabricating.
__________________
Ruttman 390
Old 03-13-2009, 03:54 PM   #5 (permalink)
Senior Member
That sounds pretty cool. I have some limited (and now very very rusty) experience with C and Java. Don't ask me anything about them because I'll have to dig out the textbooks.
Scavenging parts isn't that hard IMO, but finding fuel injectors small enough for sub-10hp engines can be difficult. I don't have any injectors smaller than 14lb/hr, which are very conservatively capable of ~17-18bhp on gas. One way to get around that is to use a fuel with a numerically lower stoich AFR so the "excess" flow capacity can be used.
__________________
Old 03-13-2009, 03:56 PM   #6 (permalink)
Senior Member
Stang's Avatar
Here is a current profile, for an amplified common rail fuel injection system. This is only the main injection pulse, there is also a post injection. Each injection actually has 3 "micro" injections and it also features negative current to open and close the spool faster. Purple is open coil, Green is close coil.
__________________
Ruttman 390
Old 03-13-2009, 07:32 PM   #7 (permalink)
Senior Member
Hmm, now my mind is working on direct injection for a gasser.
I need to track down a flex fuel sensor too...
__________________
Old 03-13-2009, 11:12 PM   #8 (permalink)
Senior Member
GTLabs's Avatar
Cool! Our own great big pile of stinkin' tech info! Gotta love it ;).
Here is the FFV sensor you're looking for. They're pricey, though. They were also only on a few years of FFVs. You'd have to wire it, supply the power, and plumb the fuel lines from an external source. I could see larger generators benefitting from that, but a minibike just makes it too complicated to fit. That sensor is about a pound or two with its own internal logic.
http://usa.vdo.com/products_solution...x-fuel-sensor/
I have some C and assembler experience as far as bit level languages go. I got really into Japanese ECUS from Denso and Unisia. I was trying to hack my RS forever but it has a funky chip set that doesn't take well to reflashing.
I think we would be able to whip up something very basic that uses a low level of current draw. Take a look at this water injection setup. It has a 10ma draw and can handle pressures from 3-30psi. I think it could be fun and simple enough. If you guys aren't up on the analog dial idea, then maybe we can get a small digital controller with 3D mapping.
https://www.precisiontuning.com/stor...14&page=1&js=n
I thought about this more last night. (BTW, thanks for the ignition replies. We can deal with that separately.) Finding the right sized fuel injector is indeed a problem. For the TB, I think we can find one that is the right size that is triggered off of the TPS. If we just concentrate on fuel delivery, then that'll minimize our technical requirements and electric current needs.
If ignition curves and timing are easily changed, then I wouldn't want to mess with that separate system or make it more complicated than necessary.
GTLabs is offline   Reply With Quote
Old 03-13-2009, 11:59 PM   #9 (permalink)
Senior Member
I have heard of cheaper ways to get the FFV fuel sensors. I just have to verify the source yet....
__________________
Old 03-14-2009, 03:40 AM   #10 (permalink)
Senior Member
Stang's Avatar
Quote:
Originally Posted by GTLabs View Post
Funny you picked that,I work for Continental lol, former Siemens VDO automotive. Wonder if I get a discount on sensors like their tires :/
__________________
Ruttman 390
Reply
Lower Navigation
Tags
electronic, fuel, great, injection, thread!
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0 RC2 Copyright 2006-2009 OldMiniBikes.com / OMB Group LLC
no new posts
