Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Thread Tools Display Modes
Old 02-10-2010, 12:20 AM   #1 (permalink)
Senior Member
mhornfeck72205's Avatar
Handheld engine starters? Making mine from a briggs electric start.
Hey all. Just a few questions on engine starters.
Did you buy yours or make it yourself? If you bought it, are there any sites to get some ideas from?
I'm going to try to assemble my own, on the cheap, to start my engines instead of using a pull start. I have a briggs starter motor with a bare shaft and a 12v 7ah battery. If 7ah isnt high enough, I also have a 17ah to use. I'm going mount it all to a base plate and put handles on it with a switch to turn it on and off.
I'm planning on welding a 3/8" socket extender onto the shaft to be able to use sockets on the end of it. Just gotta make sure that it is centered. I may also try to shave the shaft down to 1/4" square and put a 1/4" to 3/8" size-up adapter on it and then weld that in place.
mhornfeck72205 is offline   Reply With Quote
Old 02-10-2010, 02:01 AM   #2 (permalink)
Senior Member
Oldsalt's Avatar
Will a Briggs starter, without the big ring gear attached to the flywheel, have enough torque to turn over the motor? How about putting a small pulley on the starter and a larger pulley on the crankshaft and use a belt between the two?
Oldsalt is offline   Reply With Quote
Old 02-11-2010, 07:36 PM   #3 (permalink)
Senior Member
Jay Wrix's Avatar
On 4cycle.com there was someone that made a beautiful hand held starter out of an old Subaru starter ( for a car, im assuming a small motor) but It lasted forever, looked great and cost sixty dollars, best of all he had a step by step on how to doit,
Ill try to find it later1
Jay Wrix is offline   Reply With Quote
Old 02-11-2010, 08:19 PM   #4 (permalink)
Senior Member
im thinking that a standard briggs started wont have the power to turn a motor over like that .you would need some kind of gear reduction . if you built it off a car starter it would have the power to do it with out gears. what kind of ratchet or over run clutch are you going to use ? you would need some kind of clutch so when the motor starts it wont break your arm by flipping the starter out of your hand.
metal man is offline   Reply With Quote
Old 02-11-2010, 08:46 PM   #5 (permalink)
Senior Member
I have a hunch that the briggs will be torque-y enough. I'm just going to build it and see if it works or not. If it doesnt, I always have my cordless drill which works just fine now. Just looking to make something that lasts a bit longer than the drill.
When the engine kicks in, it should just spin the briggs shaft faster.. I dont think it would really rip it out of my hand. The starter shaft isnt attached to anything directly linked to the rest of the starter. It spins freely.
Old 02-11-2010, 09:31 PM   #6 (permalink)
Senior Member
DreyeIce's Avatar
any briggs or tech i have had starts is 2 light pulls, max, whats the problem with pulling the cord?
DreyeIce is offline   Reply With Quote
Old 02-11-2010, 09:41 PM   #7 (permalink)
Senior Member
its for my honda clone which I've added a ton of mods to. It has the compression release removed on it too.
Old 02-11-2010, 09:49 PM   #8 (permalink)
Senior Member
Oldsalt's Avatar
The raw Briggs starter motor will not have enough torque, without the huge reduction supplied by the stock ring gear normally mounted on the flywheel, to turn over the motor. If a car starter, which often have internal reduction gearing, is used there is going to be a problem holding on to the starter. The torque is instantly applied when the switch is closed. The starter will hit top RPM and torque almost instantly. A gorrilla couldn't be counted on to hold on to it useing both hands when the engine hit it's first compression sroke. Install long handles? Reduce the voltage to weaken the car starter's output? Then there is the problem of a "bendix" or some other form of over-running clutch.
A belt drive, with a small pulley on the Briggs starter [hand held] and a larger pulley on the flywheel side of the crankshaft, would have a good chance of eliminating of minimizing the above noted problems......IMHO. The starter motor could be enerigized before it's pulled up tightly against the "V" belt. That would allow the torque to be "clutched" in rather than being suddenly engaged and wrapping the cables around your arms. The small and large pulleys would supply a reduction that would, hopefully, allow the little starter to work. The engine when it starts would not be hard coupled to the starter so an over-run clutch would not be required. The loose belt would simply fall off on the ground when the starter allowed the belt to be free.
That would be my direction if the aim was to have a starter that was safe and low buck.
Old 02-11-2010, 09:58 PM   #9 (permalink)
Senior Member
A cordless drill has a reduction built in. Why do I not have such a hard time turning the engine over with the drill?
Old 02-11-2010, 10:36 PM   #10 (permalink)
Senior Member
Oldsalt's Avatar
Try the Briggs starter without reduction and let us know if it turns over the engine adaquately. If I'm dead wrong on that matter, you got it done! Well, it might still be necessary to have some form of over-running clutch.
If, on the other hand, the Briggs starter will not turn over the engine adaquately get yourself a car starter and plug that onto the end of the crankshaft and see if it can be held onto. I, for one, would like for you to have a friend there to turn on the switch and take a picture at exactly the same instant. Then post the picture when you are again able to operate a keyboard.
Reply
Lower Navigation
Tags
engine, handheld, starters?
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
LIGHTED BRIGGS 5 horse flatty with electric start The Restore Kid Mini Bike Parts 3 11-22-2010 12:36 PM
Free Kohler Electric start engine wjustice Mini Bike Parts 0 09-25-2010 04:11 PM
electric start DB-30 cjtmini Doodlebug MiniBikes 17 08-17-2009 07:09 PM
briggs electric start black_ice Briggs & Stratton Engines 11 06-30-2009 10:24 AM
Wanted Electric start engine shoe Mini Bikes & Parts WANTED 0 10-06-2008 11:39 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
