Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Thread Tools Display Modes
Old 04-05-2010, 12:57 AM   #1 (permalink)
Senior Member
azndude3141's Avatar
Unhappy how do i hook up a kill switch to a B@S engine?
its just a normal 3.5 hp engine. can u show me some pics on how to hook it up? here is the engine im planning to connect it to,
azndude3141 is offline   Reply With Quote
Old 04-05-2010, 01:54 AM   #2 (permalink)
Killswitch??
this post talks about it its on a tec but a briggs is the same basic thing
metal man is offline   Reply With Quote
Old 04-05-2010, 04:44 AM   #3 (permalink)
Senior Member
osoverns's Avatar
well im not sure about your motor but it looks awefully close to mine plus its been the same for me on all briggs that i have installed a kill switch on... on your bike in particular look behind the plate that has the throttle and choke arms coming out. there should be a wire connected to it and then when either the choke is in the off position or when the gas is in the off position(ive seen them on either one) the lever grounds the wire out..... so what you need to do is remove that wire it should just take you pressing down a metal contraption they use to hold it down i wouldnt cut it because there will not be a lot to work with anyway.. now get your kill switch the kind with one wire coming off and screws to your handle bar and connect it to that one wire you just took off that plate
osoverns is offline   Reply With Quote
Old 04-05-2010, 08:59 AM   #4 (permalink)
Banned
MetalMan said the same thing I was gonna say, there definitely should be a wire attached to one of the levers, I have a 3.5 and a 5hp with the same setup and both had kill switches there.
supernova is offline   Reply With Quote
Old 04-05-2010, 05:19 PM   #5 (permalink)
Senior Member
ok, i checked behind the plate and i saw a black wire. do i just connect the kill switch to that black wire?
Old 04-05-2010, 05:29 PM   #6 (permalink)
guardrail dave's Avatar
yes /that should be the wire /to test hook up a piece of scrap wire start the engine then press the other end of the wire to a head bolt and it should stop the engine /dont touch bare spots on the wire ends or you will get shocked
guardrail dave is offline   Reply With Quote
Old 04-05-2010, 05:43 PM   #7 (permalink)
Senior Member
will it electrocute me when i touch the black wire?
Old 04-05-2010, 06:28 PM   #8 (permalink)
if you touch a bare spot on the wire when its running only it will shock you not eletrocute you shock you if your worried wear rubber gloves and rubbersoul shoes /i thought you would be finished with the test kill already
Old 04-06-2010, 03:30 AM   #9 (permalink)
Senior Member
osoverns's Avatar
no no ... you have to take the black wire thats connected to the plug on the top of the motor ... hold it and try and pull start your engine
Reply
Lower Navigation
Tags
engine?, hook, kill, switch
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Kill Switch For A HF 6.5 KingPaul Honda / Clone / Predator Engines 5 08-04-2010 10:54 PM
Need help please with a key kill switch eman193 Honda / Clone / Predator Engines 24 06-20-2010 09:45 PM
Kill Switch Truckasaurus44 Engines and Modifications 4 04-16-2010 09:08 PM
Kill switch hook-up??? RiderZ Tecumseh Engines 3 06-25-2009 07:30 PM
need help with kill switch jeff04propred Briggs & Stratton Engines 6 03-16-2009 05:10 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
