Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Old 08-09-2008, 01:21 PM   #1 (permalink)
randyk72@verizon's Avatar
Visually I.D'ing Tec engines
Is there a way to ID Tech engines if you dont have a number. I normally work with briggs and on them you can ID them by casting numbers on the head, crank, etc. I have two tecs and the one has it's tag HS35 and the other does not. You guys on the board I.D it as a HS40.. but how can you tell? I also seen where some Tec have the exhaust on the L or R side. Any help would be great. Also I'll asume that 30 is 3 hp, 50 is 5 hp and so on?
Randy
randyk72@verizon is offline   Reply With Quote
Old 08-09-2008, 01:51 PM   #2 (permalink)
Here's all I've seen from what I've collected. The HS35 intake is on the right, exhaust on left. The HS40 & HS50 intake is on the left, exhaust on the right.
Most H30s have the intake on the right and the exhaust out the left side, not out the rear on the left side but straight out the PTO side. The older H40,50,60,and 70 have the intake on the right and exhaust on the left, and are a bigger block. They also have 4 threaded holes in the bottom of the block for a mounting plate that adapts them to standard small engine pattern.
The HH series are cast iron bigger blocks.
Your assumption is right. 30 is 3hp 40 is 4hp, etc.
jimh is offline   Reply With Quote
Old 08-09-2008, 02:04 PM   #3 (permalink)
Senior Member
jesse8931's Avatar
hs = small block. h = big block
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
Heald Super Bronc VT 10
2 Honda CT 90's
jesse8931 is offline   Reply With Quote
Old 08-09-2008, 02:11 PM   #4 (permalink)
So how can you tell a 40 from a 50? Is bore and stroke the only way?
Thanks guys.
Old 08-09-2008, 02:41 PM   #5 (permalink)
I believe the 50 has a bigger bore, same stroke. The cranks are balanced different, so they're not interchangable. The H= big block only works on the older H40-70. They're actually medium blocks. The HM80-100s are the big blocks. The H30 is a small block and the newer H series Powersports are small blocks.
Old 08-09-2008, 11:52 PM   #6 (permalink)
Senior Member
jesse8931's Avatar
duh i forgot about the hm blocks
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
2 Honda CT 90's
Reply
Tags
engines, i.d'ing, visually
Thread Tools
Display Modes
