Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Old 08-19-2008, 04:15 PM   #11 (permalink)
Member
silicone used to repair leaking head bolt
what kind of silicone? where did you get it. thanks, John
__________________
Thanks, John C.
jscap99 is offline   Reply With Quote
Old 08-21-2008, 04:17 PM   #12 (permalink)
Member
silicone
What kind of silicone? I might try that first. Thanks, John
__________________
Thanks, John C.
Old 08-21-2008, 06:40 PM   #13 (permalink)
den35's Avatar
Wonder if automotive RTV sealant(the stuff used on the ends of a car engine intake manifold) would work.It's made for heat and pressure.
__________________
Keep the wheels on the bottom.
den35 is offline   Reply With Quote
Old 08-28-2008, 01:51 AM   #14 (permalink)
Junior Member
bugman53's Avatar
better idea get a copper washer used in banjo bolts and brake lines and put it under the leaking bolt and that will seal that leak.
But really silcone to fix a head bolt. I not trying to insult anyone but that suff might old 5psi not 150 psi in a cylinder head. If its just a oil leak then thats different but a head bolt.
If is leaking compression then have the head surfaced. and get a good gasket and there will not be a leak. Its a flat head, not a OHC watercooled race motor(and yes i build race motors for a living)
But the copper washer would hold. My concern is hot gases geting past the fire ring in the head and causing the gasket to burn up.
If a head gasket ever leakes for a few seconds then the gasket is toast.
__________________
1968? Bird(10inch wheels..model?) w\a 5hp briggs(stock was a 3.5 tec)
1971 Rupp roadster 4hp Tec.
1972 Honda Mini Trail z50 (under restoration)
2005 Kawasaki ZX10R W/172RWHP..394lb. wet...
bugman53 is offline   Reply With Quote
Old 08-28-2008, 02:00 AM   #15 (permalink)
Junior Member
bugman53's Avatar
I just read that you have a new head. What kind of gasket are you running?
We will get her fixed for you.
a quick trick to make sure the head is flat. Take a peice of glass and lay some 400grit sand papper on it and move the head in figure 8 patterns and look at the smooth parts on the bottom of the head. you will quickly see if there are any low spots. you can do this for a wile and get the head pretty flat. It is possable that the new head has warped if the casting was not aged before maching.
__________________
Old 08-31-2008, 06:48 PM   #16 (permalink)
Member
leaking at the head
It's a new gasket on there, not a new head. The gasket is OEM and copper. I also used some copper spray sealant. still leaks.
When I get to it I want to try truing up the head with sandpaper, although I don't have any plate glass. I also heard you can use a file to do this, but I don't want to ruin it.
I would like to get this head surfaced but don't know where to look to have it done. any ideas on getting the head surfaced?
I guess using silicone as a sealant is not a good idea?
-John
__________________
Thanks, John C.
Old 08-31-2008, 09:41 PM   #17 (permalink)
Member
Why don't you just put a heli-coil in the block and be done with it and quit fooling around with band-aid gasket sealers
Rhovis is offline   Reply With Quote
Old 09-01-2008, 04:45 PM   #18 (permalink)
Member
head leak
The bolt and threads appeared to be in good shape. I hear you about the sealers. The tecumseh book says not to use sealers. You just make sure the head is true and replace the gasket.
I'm going to take it apart soon. When I put it back I'm going to use a brass washer. I might want to get the head resurfaced but I don't want to spend that much. At a harbor freight near me they have the 6.5hp clone for $100.
John
__________________
Thanks, John C.
Reply
Tags
bolt, head, leaking, repair, silicone(?)
Thread Tools
Display Modes
