Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Old 08-11-2008, 03:36 PM   #1 (permalink)
den35's Avatar
Drill size help!
I was going to try drilling out the jets on my 5.5 clone and my original Doodlebug engine,but I hit a snag.
All the posts here talk about drills with number sizes(eg,#64 bit).But all my bits are standard measure.(My smallest is 3/64")
Does anyone know what size bit I should use(in standard measure) for each engine?I don't want to use the wrong size and mess up my engines.
__________________
Keep the wheels on the bottom.
den35 is offline   Reply With Quote
Old 08-11-2008, 03:54 PM   #2 (permalink)
Junior Member
A 3/64 is about a number 56 bit. you will need something smaller than that for your carburetor jets. I just opened the jet on my 6.5 clone this weekend to a number 68 ( stock was a number 70). A 56 would be too rich. What you need is to get an index of small drill bits. McMaster Carr offers one which goes from #61 to # 80. This works really well as you can find which size just fits in the stock jet hole and then drill with the next size up, test and see if you need more.
rasndas is offline   Reply With Quote
Old 08-11-2008, 04:02 PM   #3 (permalink)
den35's Avatar
Crap.I was hoping to just use what I had on hand.Oh well.Payday is comming,I suppose.
Thanks,Rasndas.
__________________
Old 08-11-2008, 09:15 PM   #4 (permalink)
cjtmini's Avatar
be careful drilling the jets with the tiny drill bits
I put the drill bit in the vise and then "drill" the jet carefully over the drill bit by hand
Start small, you can always go bigger
Number size bits are different than fractional bits
cjtmini is offline   Reply With Quote
Old 08-15-2008, 02:10 AM   #5 (permalink)
Senior Member
65ShelbyClone's Avatar
Go on Google Images and type in "drill chart". That will give you a cross reference for all the drill sizes; number, letter, and fractional.
The clone carb is in all likelihood a ripoff of the Keihins that Honda uses. If that's the case, then the jets are sized in tenths of a millimeter. A 68 jet has an orifice size of 0.68mm, a 70 jet is 0.70mm, etc. That will help you figure out what assortment of small drill bits you'll need.
__________________
In the streets the garbage lies
Protected by a million flies
The roaches so big you know that they got bones
Moved in and made a tenement home
65ShelbyClone is offline   Reply With Quote
Old 08-15-2008, 02:45 PM   #6 (permalink)
Senior Member
adjustable jet from nr racing is only like 15 bucks probably same price as drills and if your off you can just turn the screw instead of buy another jet and start over
5hpminitech is offline   Reply With Quote
Old 08-15-2008, 06:10 PM   #7 (permalink)
den35's Avatar
Hmm.That's an idea.I know they make them to fit the clones.But what about original DB30 engines?
__________________
Reply
Tags
drill, help!, size
Thread Tools
Display Modes
