Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Old 08-11-2008, 04:30 PM   #1 (permalink)
Junior Member
Can you replace ignition points with CDI unit?
Is it possible to replace the points on my older Tecumseh H35 with the newer H35 CDI units?
mcanders is offline   Reply With Quote
Old 08-17-2008, 02:10 PM   #2 (permalink)
Yellowhand's Avatar
Yes...
I've even put Tecumseh CDI units on older Briggs & Stratton engines to eliminate the need for points...just slot the mounting holes on the unit to compensate for the slight difference in mounting hole ctr-ctr distance...
Also, the lifespan of most CDI units is virtually forever, so, rather than buy them as new OEM replacement parts, I buy junk pushmowers at swaps and fleas, and strip them of usable parts...
Many vertical shaft engine components found on mowers are direct replacement parts for similar size horizontal shaft engines...
Yellowhand is offline   Reply With Quote
Old 08-17-2008, 02:22 PM   #3 (permalink)
Make sure your coil isn't under the flywheel. If it is, you may be stuck. The ones from the 80s had the coil on the outside and the points and condenser under the flywheel. On these, you can swap coils. The earlier ones don't have the posts above the flywheel for mounting the coil.
jimh is offline   Reply With Quote
Old 08-17-2008, 03:05 PM   #4 (permalink)
Senior Member
jesse8931's Avatar
jimh you can get a kit for the older tec's i plan to put one on that h70 you gave me so you can have your special one back
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
Heald Super Bronc VT 10
2 Honda CT 90's
jesse8931 is offline   Reply With Quote
Old 08-18-2008, 03:28 PM   #5 (permalink)
Junior Member
Well my magnets and coil is under the flywheel so I guess I'm out of luck.
Old 08-19-2008, 12:19 AM   #6 (permalink)
Senior Member
jesse8931's Avatar
go to your local lawn mower shop and have them order the electronic ignition kit for your motor
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
2 Honda CT 90's
Reply
Tags
ignition, points, replace, unit?
Thread Tools
Display Modes
