Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Old 08-13-2008, 12:16 PM   #1 (permalink)
GTO
GTO's Avatar
Noise in head?
I have a 3 HP Briggs that runs great and doesn't smoke but under load and mid to high RPM I'm getting a tapping/knocking/peening noise coming from the top of the head. I pulled the plug and it doesn't look like the piston is hitting it so could it be the valves? I adjusted the carb many times.
BTW, this engine had the air flap gov that was connected to the throttle that I removed.
__________________
I don't like to be Governed.
GTO is offline   Reply With Quote
Old 08-13-2008, 12:21 PM   #2 (permalink)
Senior Member
jesse8931's Avatar
pull the head i bet the valve is smacking the head
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
Heald Super Bronc VT 10
2 Honda CT 90's
jesse8931 is offline   Reply With Quote
Old 08-13-2008, 12:22 PM   #3 (permalink)
GTO
GTO's Avatar
Quote:
Yes but why?
__________________
Old 08-13-2008, 12:25 PM   #4 (permalink)
Senior Member
jesse8931's Avatar
it could be a lot of things
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
2 Honda CT 90's
Old 08-13-2008, 12:28 PM   #5 (permalink)
GTO
GTO's Avatar
The engine is stock and newer with few hours so maybe the air gov types were never intended for any real RPM ?
__________________
Old 08-13-2008, 12:53 PM   #6 (permalink)
Senior Member
jesse8931's Avatar
maybe the springs are to weak to handle the rpm's you need on a mini bike
__________________
Lil Indian Sabre
Rupp Roadster 2
Mtd Trail Flite
Mtd Mini Cycle
2 Honda CT 90's
Old 08-13-2008, 01:31 PM   #7 (permalink)
Senior Member
I agree with Jesse. without the governer your springs are put under alot more stress
blownengine is offline   Reply With Quote
Old 08-14-2008, 09:14 AM   #8 (permalink)
Junior Member
Measure the length of your stock exhaust spring and then call Dyno Cams 910-655-9035 ask for stock aftermarket springs for a 5hp the same length. These springs will be approx 3 to 5 lbs more pressure and should eliminate valve float. I do caution you because after installing these springs the engine will turn more rpm's and you will have a much greater chance of having a internal problem like a rod or piston failure. The better solution maybe to try and lower the gear ratio on your bike
EZBORE is offline   Reply With Quote
Old 08-14-2008, 01:38 PM   #9 (permalink)
GTO
GTO's Avatar
Quote:
The gears won't matter becaue it does it at mid RPM under load so I guees I'll take the springs out and compair them with one of my parts engines 3 & 5HP. I wonder if a spacer washer would help.
__________________
Old 08-14-2008, 02:17 PM   #10 (permalink)
Junior Member
Is it possible this motor has a rod knock ? -- Rod or piston noises are heard under load Valve float occurs normally at higher rpms -- Are you seeing metal particle when you drain the oil.
Reply
Tags
head?, noise
Thread Tools
Display Modes
