Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Old 08-20-2008, 01:59 AM   #1 (permalink)
Junior Member
Clutch Problems
Recently I went and bought a 6.5hp clone engine from Costco for my DB30.
I went and bought a 3/4 comet clutch from Princess auto, the problem is it wont fit on my shaft..
The shaft has a key coming out from it..and the clutch has a key as well...so no way to get on.
Are there other clutches out there that don't come with key's?
or will i have to cut the key off the shaft?
Thanks.
ChimpFeces is offline   Reply With Quote
Old 08-20-2008, 03:50 AM   #2 (permalink)
GTO
GTO's Avatar
are you sure the key doesn't come off the engine? Max torque used to make a clutch where you add a key so give them a call.
I would double check the key on the engine tough, that should come off. What brand engine? Champion?
__________________
I don't like to be Governed.
GTO is offline   Reply With Quote
Old 08-20-2008, 06:51 AM   #3 (permalink)
Senior Member
Hey Monkey Poop...............
Grab the key on the shaft with a pair of vice grips and pull it out.
deezildennis is offline   Reply With Quote
Old 08-20-2008, 09:58 AM   #4 (permalink)
den35's Avatar
Both my Max-Torques came with the key separate.Most keys are removeable.A few taps with a hammer and punch will pop them out.(the only one I've seen with the key pemanently fixed to the clutch is the stock DB30 clutch.)
I don't know if anyone else had this problem,but I had to polish the bore of my new clutch with a moto-tool and a sanding drum to get it onto the shaft.Seems the shaft and the bore were EXACTLY 5/8",and it wouldn't fit.But after a few passes with the sander,it slid right on.
__________________
Keep the wheels on the bottom.
den35 is offline   Reply With Quote
Old 08-20-2008, 11:21 AM   #5 (permalink)
Yellowhand's Avatar
Hilliard brand clutches have a non-replaceable bronze key cast right into the bushing/shoe hub assembly...something to think about if you're pushing enough torque to twist off a key...
Interesting screen name...must be a story there somewhere...
Yellowhand is offline   Reply With Quote
Old 08-20-2008, 11:51 AM   #6 (permalink)
den35's Avatar
[quote=Yellowhand;42222]Hilliard brand clutches have a non-replaceable bronze key cast right into the bushing/shoe hub assembly...something to think about if you're pushing enough torque to twist off a key...
QUOTE]
Really.Makes me wonder if the stock DB30 clutch is a Hillard.If so,I know to avoid them now.
__________________
Old 08-20-2008, 12:40 PM   #7 (permalink)
Junior Member
Thanks for the info, and yes it is a Champion.
I will quickly check to see if its possible for me to take the key off the engine shaft.
Old 08-20-2008, 01:17 PM   #8 (permalink)
Junior Member
Woot, thanks a bunch.
I was able to slide the key out easy.
Old 08-20-2008, 01:20 PM   #9 (permalink)
Senior Member
I have a champion too, the key will be in the shaft pretty tight, but it will come out with some work.
xspike77x is offline   Reply With Quote
Old 08-20-2008, 01:44 PM   #10 (permalink)
GTO
GTO's Avatar
I've bought quite a few new clutches and neither came with the key separate, they look swagged or brazed in. Never had to polish the bore of a clutch to get one on either.
__________________
Reply
Tags
clutch, problems
Thread Tools
Display Modes
