Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Old 08-22-2008, 03:16 PM   #1 (permalink)
Senior Member
rear sprocket
I need a rear sprocket for my Manco Streaker project. Its only powered by a 2 horse Briggs so would i be correct in assuming that i want the largest sprocket possible so i can get some acceleration from the small engine.
I ride around my yard which isnt huge so i am looking for more acceleration then top speed.
The largest sprocket i could find was a 72 tooth. Would this work fine? From what i have looked at that is as large as i can go because my tires are only 10 inches in diameter.
blownengine is offline   Reply With Quote
Old 08-22-2008, 03:59 PM   #2 (permalink)
GTO
GTO's Avatar
With only 5" rims you run the risk of bottoming out the sprocket in turns or in the grass. A bolt on jack shaft might be the ticket or weld one on.
__________________
I don't like to be Governed.
GTO is offline   Reply With Quote
Old 08-22-2008, 04:39 PM   #3 (permalink)
Senior Member
i thought about a jackshaft but it would interfere with my scrub brake.
And a 72 tooth sprocket is 8-3/4 inches in diameter so that gives me 1-1/4 inches clearance since me tires are 10 inches in diameter. I just have to make sure the tires are fully inflated
Old 08-22-2008, 06:58 PM   #4 (permalink)
Won't you only have 5/8" clearance? Half of you diameter difference? That's not much.
jimh is offline   Reply With Quote
Old 08-22-2008, 11:57 PM   #5 (permalink)
Go with a 60 tooth sprocket and strap on a nitrous kit for the 2 HP baby Briggs LOL
There is a bolt on jack shaft kit made by Maxi-Torque but I don't think your little engine has the 4 mounting holes in the side cover. It may be time to get a bigger engine so you can streak in style on your Manco Streaker.
Steve
steven Durham is online now   Reply With Quote
Old 08-24-2008, 12:15 AM   #6 (permalink)
Senior Member
Jim i dont understand what you are trying to say.
My tires are 10" in diameter, minus the 8-3/4" sprocket gives me 1-1/4" clearence between the sprocket and the ground.
And a 2 horse was all i could get my hands on, in the future i will definetly be looking for a bigger engine
__________________
Lil' Indian Sabre, 6.5 Honda -Rider
Manco Streaker, 5hp Tecumseh -In progress
Old 08-24-2008, 01:56 AM   #7 (permalink)
GTO
GTO's Avatar
I would wait for a bigger engine, over 3.5HP though and it sticks way out the side on the little Steakers. A 72 T on a 5" rim is too big, I'd be grinding the chain of on every turn and bump.
__________________
Old 08-24-2008, 02:32 AM   #8 (permalink)
Senior Member
truckster52's Avatar
Yes on the diameter you have 1 1/4" but when you stick an axle through the center of both of them you are now working with the radius, which is half of the diameter. 5" minus 4 3/8" = 5/8". That is the distance the sprocket will be from the ground with an inflated tire. Add the chain and sit on it and it gets even closer to the ground. Hope this helps.
__________________
1952 Ford F1
1931 Ford coupe (project)
1969 Ford F100
Bonanza BC1300T
Bonanza MX1510
Bonanza CR500
1967 John Deere 112
truckster52 is offline   Reply With Quote
Reply
Tags
rear, sprocket
Thread Tools
Display Modes
