Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Thread Tools Display Modes
Old 09-01-2008, 04:16 PM   #1 (permalink)
Junior Member
Please help with B&S throttle return spring/governor linkage assembly.
I am stuck trying to configure the throttle return spring/governor linkage assembly on a B&S 10hp Synchro-Balanced that need to have remote throttle. This Model-251417, Type-0153-01, horizontal engine runs strong but was in need of carburetor repair. I have the B&S manuals but there is no clear diagram of how this particular setup should be. My best guess is that there has been some shade-tree work done in an attempt to relocate the throttle thereby bypassing the governor but I don’t really know for sure (see throttle mount bracket on old carburetor). For everyone’s convenience I have posted high resolution pictures of the all new parts assembly so far on my website withSolutions NOTE: This is not a marketing website.
Thank you in advance for any help.
wally3692000 is offline   Reply With Quote
Old 09-01-2008, 05:48 PM   #2 (permalink)
Member
First off,
Howdy Wally,
The throttle linkage is fairly basic, but can sure seem strange at first. Let me know how much you know about them, but I will give you some basics now.
If I need to elaborate, please feel free to ask..If I give too much detail, please forgive, just trying to help.
The key to the whole thing is the throttle butterfly. It is inside the barrel of the carb, you can't see it when the carb is installed, but it is actuated by the throttle arm which you CAN see. They are both on a common shaft.
The throttle arm also has an idle limit screw to control how far the throttle can close (Just enough for a steady, even idle when warmed up).
The throttle arm should be linked directly to the governor arm which sticks out of the crank case. Usually fairly long, several holes in the end to allow a variety of strengths of spring.
There is also a "Throttle Spring" that connects to the "Throttle Plate" which is actually another moving arm. The Throttle plate also has a stop to limit how high the throttle can go (the 4 positions for the stop screw on yours), and sometimes a kill blade that is connected to the ignition coil, and is grounded by the throttle plate when the throttle is set to the 'Off" position.
The throttle plate is also the piece that your throttle cable connects to.
The Governor arm often doesn't feel like it does anything until the engine is running. Then, it pulls toward the low throttle position, closing the butterfly down to the idle position as set by the idle screw (Not to be confused with "Idle Mixture" which sets the lean/rich mixture at idle).
When you throttle up, you are pulling the throttle plate, which stretches the spring between the throttle plate and the governor arm, thus pulling the governor arm away from the idle position, and increasing the engine speed.
Once the speed has increased, then the spring and the governor find balance at the new RPM. More spring pull, more RPM. etc.
Sometimes, the spring pulls on the throttle arm instead of the governor arm. While possible, this is NOT recommended because a failure of the linkage can cause a "Runaway" condition which usually results in a spectacular and highly dangerous destruction of the engine!
Ok that should be good for starters. Once everything is in order, you should limit the high end to 3600 RPM, the design speed for most domestic 4 cycles.
If the linkages and spring are all just right, the throttle should be smooth, even, and linear through the entire range.
Coat hanger for big engines, and bike spokes or stiff music wire for the smaller engines, a couple pair of needle nose pliers and a cutter, and you can make the linkages you need. Just be sure the governor arm can pull the throttle arm all the way to idle, or the idle may rise and fall by itself.
Bart
Barticusmax is offline   Reply With Quote
Old 09-02-2008, 03:45 PM   #3 (permalink)
Junior Member
Thank you for this very concise explanation. I’m sure it will help even more people than me. My situation is that not all of the pieces of this linkage scenario where intact when I got the bike and the exploded parts diagram and the two B&S manuals I have seem to cover this for all setups in the same diagram, except for mine. If I had the opportunity to take the original apart I wouldn’t really be stuck.
All the parts involved, mostly new, are the correct for my model/type. I am confident that the connections of the governor arm, that has only two holes, one for the carburetor butterfly connecting wire rod and one for the governor spring (Picture 7) and the governor spring to the governor control plate (Picture 9) are correct.
However when I picked up the bike the throttle cable (a junk lawn mower slide assembly) was anchored on the scissors like throttle control attached to the old carb (Picture 1). My guess is that this part may have been added because it does not interface with the governor at all, so I went with mounting the new throttle cable directly to the governor control plate (Picture 12).
This leaves me lacking as where to put the throttle return spring. Best guess would suggest that it should go to one of the two remaining internal arms on the governor control plate (Picture 6) and if so where does the other end or the spring go?
Or is the scissors like throttle control still on the old carb need to come into play?
Further I need this all too work as a cycle throttle.
Old 09-02-2008, 07:19 PM   #4 (permalink)
Member
Ok, I am 80 % sure that the "Scissors" lever is a multiplexer. It applies the choke when the last 1/8th or so of full throttle is applied. It does look like the beefier spring attached could be a return for a "Soft Throttle" like minis and motorcycles use. (Soft throttle requires the return spring, firm throttle is actually push-pull with a solid core cable)
Reply
Lower Navigation
Tags
b&s throttle
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rupp vintage minibike Tecumseh throttle return spring ebay eBay Mini Bikes 0 10-16-2008 03:50 PM
Rupp vintage minibike Tecumseh throttle return spring ebay eBay Mini Bikes 0 10-08-2008 05:50 PM
Rupp vintage minibike Tecumseh throttle return spring ebay eBay Mini Bikes 0 08-25-2008 01:11 AM
Rupp vintage minibike Tecumseh throttle return spring ebay eBay Mini Bikes 0 08-14-2008 11:50 AM
Rupp vintage minibike Tecumseh throttle return spring ebay eBay Mini Bikes 0 08-14-2008 04:04 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
