Mini Bike of the Month
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications
Engines and Modifications Get the most out of your motor or just get it running! Discuss engines and modifications in depth.
Reply
Old 09-03-2008, 06:25 AM   #1 (permalink)
Junior Member
will nitrious do anything??
I have a thunderbird with the 6.5hp clone. I have access to a kit like this eBay Motors: ATV & Quad Sneaky Pete Mini Nitrous Kit w/5 NOS Refills (item 320292715929 end time Sep-08-08 07:07:35 PDT) and I want to know if it will do anything. Has anyone tried it before??
daamizin1 is offline   Reply With Quote
Old 09-03-2008, 09:05 AM   #2 (permalink)
Junior Member
Nitrous is basically liquid oxygen, if you dont add additional fuel some how it will just run way to lean. The kit could work but is very incomplete, its a 1/2 a nitrous set up.
SAFETYpin is offline   Reply With Quote
Old 09-03-2008, 09:28 AM   #3 (permalink)
Junior Member
Quote:
I know it would need more fuel, im looking for someone who has tried it because i have access to a kit like the one pictured and im curious. Any ideas for making the kit work would be appriciated.
Old 09-03-2008, 03:55 PM   #4 (permalink)
Junior Member
I have run nitrous on numerous automotive engines and it makes incredible horsepower. You have to add extra fuel with the nitrous or you will burn the piston up due to an extreemly lean condition. Nitrous is 33% usable oxygen verses the 21% found in air. The major part of the horsepower boost comes from the cooling effect of nitrous on the incomming fuel air charge. liquid nitrous boils at -127 degrees F and this causes substantial cooling of the incomming fuel air mixture and hence gives a dense charge to the cylinder. A nitrous system would work on a small engine but you need to supply both the nitrous and extra fuel in the right amounts.
rasndas is offline   Reply With Quote
Old 09-05-2008, 12:45 AM   #5 (permalink)
Senior Member
65ShelbyClone's Avatar
The power gain actually comes from the the 36% oxygen by mass that dissociates from the nitrogen and is used by the oxidation(combustion) process. It's in the same league as feeding the engine pure oxygen, but pure oxygen is a lot more unstable than oxygen bonded to nitrogen and has a tendency to explode violently instead of burn controllably. Cooling and air density increases only account for a small amount of power gain.
Considering that you would only get about one shot per cartridge, I don't think that "kit" is worth it.
__________________
In the streets the garbage lies
Protected by a million flies
The roaches so big you know that they got bones
Moved in and made a tenement home
65ShelbyClone is online now   Reply With Quote
Old 09-05-2008, 03:53 AM   #6 (permalink)
Senior Member
Stang's Avatar
I would just try one of them sneaky pete bottles and install a fogger nozzle in your intake and use a tiny jet :D
__________________
Rupp TT500 - New Project!
HPE Muskin CAT R4005
Ruttman w/ 390
Clone Block, Head (-.100, port matched and short side radius work), ARP Studs
Rotating Assembly: Honda Crank/Piston (Milled Flat, Cryo treated)/CAM (NR 320 Grind), ARC Rod, Adj. Flywheel (30deg)
Valvetrain: Stainless Valves, 32lb Springs, Aluminum Retainers/Locks, Chromoly Pushrods
Induction & Exhaust: AGK Billet Intake, Mikuni 34mm Flatslide & Fuel Pump, Cloth Filter, Custom 1.5" Header and brace
Stang is offline   Reply With Quote
Old 09-05-2008, 03:57 PM   #7 (permalink)
Junior Member
GotParts's Avatar
Quote:
i would like to see a fogger set up on a minidragbike motor. with a good chassi set up.
__________________
Need Honda GX2/Clone parts, drop me a PM and let me know what you need.
GotParts is offline   Reply With Quote
Old 09-06-2008, 05:37 PM   #8 (permalink)
Supporting Speed Nut!
Moderator
Moderator
minidragbike's Avatar
No need for a 1-2hp fogger setup when the power is already there.
__________________
Push hard, or don't push at all!
minidragbike is offline   Reply With Quote
Old 09-10-2008, 02:02 AM   #9 (permalink)
Senior Member
N2O doesn't add any extra power by itself.
It's the extra fuel that the N2O allows you to burn that produces the power.
~JM~ is offline   Reply With Quote
Old 09-13-2008, 04:53 PM   #10 (permalink)
Junior Member
couldnt you just find a bigger carb that fits? my friend rigged a yz125 dirt bike motors carb on a tecumseh hs40. it dumped alot of gas into it. so much that it shot 4 foot flames out of the exhaust
dannywood is offline   Reply With Quote
Reply
Tags
anything??, nitrious
Thread Tools
Display Modes
