Register Members List Calendar Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > General MiniBike Talk
General MiniBike Talk Talk about all topics regarding Mini Bikes. All Makes, All Models
Reply
Thread Tools Display Modes
Old 09-22-2006, 11:06 AM   #1 (permalink)
Junior Member
New engine choice for a Rupp Roadster2
I am looking to replace my original existing engine on my Rupp Roadster2 (early 70's model) with a new Tecumseh 4HP engine. I am looking for a simple bolt-in with no modifications. It seems that an easy replacement motor is the H40, but there seems to be many types of H40's out there. I've seen H40-55816, H40-55820, etc. Which motor works the best as far as throttle linkage hookups? Which internet company has the best price?
Thanks in advance!
87roadracer is offline   Reply With Quote
Old 09-22-2006, 04:39 PM   #2 (permalink)
Member
Thumbs up new engine choice
I think the motor your looking for is the hs40. Different from the h40. the hs is a smaller block. You would need a slant type intake pipe and the throttle linkage. A hs50 would work also, they're 5hp. hope this helped. Thanks, John
jscap99 is offline   Reply With Quote
Old 09-23-2006, 08:23 AM   #3 (permalink)
Senior Member
RuppParts's Avatar
Current production Tecumseh engine will be the hm40. It has minibike throttle linkage already installed. The new engines do not have mixture adjustments on the carbs and can make for engine being tempermental. The correct "early" model carbs will fit the new engines. The new engines do NOT have lighting coils. I have a dependable kit to install the lighting coils easily. I also have the carbs and engines are to be here late next week.
RuppParts is offline   Reply With Quote
Old 09-23-2006, 08:57 AM   #4 (permalink)
x-90 rider's Avatar
Brandt,
Do you need to install a spacer for the primary clutch. Is the output end of the crankshaft shorter on the new engines?
x-90 rider is offline   Reply With Quote
Old 09-23-2006, 10:13 PM   #5 (permalink)
Junior Member
Thanks for the info guys! I'll be looking into a new Tecumseh for my Roadster2.
wilpete is offline   Reply With Quote
Old 09-24-2006, 08:56 PM   #6 (permalink)
Senior Member
I90Roadking's Avatar
Hi Brandt
I have been looking into replacement motors for Arctic Cats. Other than no lighting coil, is the H40-55816 a bad move? The motors that you will be getting in, will they take a Comet Series 20 driver? Will you be placing on your web page?
Thanks
I90
I90Roadking is offline   Reply With Quote
Old 10-03-2006, 06:29 PM   #7 (permalink)
Senior Member
RuppParts's Avatar
New Tec engines
Quote:
Originally Posted by x-90 rider View Post
Brandt,
The Rupp bushing is made of tool steel. No spacers needed when replacing an orginal Rupp engine with a new engine with shorter crank. All you need is a longer bolt and your set go go!
Old 10-03-2006, 06:31 PM   #8 (permalink)
Senior Member
RuppParts's Avatar
all the late model Tec h40 engines are good choices. You may eventually need to put an early carb on it, so carb can be tuned properly for your elevation and weather conditions. The sealed carbs used now aren't a fault of Tecumseh, its the government and their clean air standards.
The newer Tec engine will accept a Comet 20, 30 or TC88 driver
Old 10-03-2006, 11:09 PM   #9 (permalink)
Senior Member
Thanks Brandt, appretiate the feedback.
Reply
Lower Navigation
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rupp Engine Choice? alfalfa General MiniBike Talk 2 04-13-2010 08:51 AM
Speedway/Fox Vintage Minibike Tank-Choice of 1 Not/Rupp ebay eBay Mini Bikes 0 02-28-2010 07:20 PM
1972 Rupp Roadster2 F/S jafgreen Complete Mini Bikes 1 11-12-2008 10:37 AM
flywheel for a rupp roadster2 tfreddy Mini Bikes & Parts WANTED 8 05-13-2008 08:14 PM
New and need advise on engine choice htyper96 Engines and Modifications 3 04-08-2008 02:10 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2 Copyright 2006-2011 OldMiniBikes.com / OMB Group LLC
no new posts
