Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Member flatheadpopup's Avatar
    Join Date
    Jan 2010
    Location
    Colorado Springs, Colorado
    Posts
    59
    Rides
    what engine and converter for Tote Gote?
    I picked up this Tote Gote (or similar) this last week without an engine or converter and am wondering what would be the best setup to get this thing up and going? I don't mind fabricating to make things work and originality isn't my highest priority at this time. Here are a couple of pics in case it helps figure out what might be most appropriate.
    Thanks for the info guys.
  2. #2
    steven Durham's Avatar
    Join Date
    Jan 2008
    Location
    Portland , Oregon
    Posts
    8,850
    Rides
    Welcome Flatheadpopup : Well I don't think it is a Tote Gote but it shares a lot of like features. With the double jack shaft your gearing will be low like a gote , But the slide adjustable v belt pully in the picture I don't think the system used a Torque Converter it may of only had a centrifugal clutch. Better close up pictures of the two jack shafts and the type of brake would help. Looks like a well built machine.
    Steve
  3. #3
    Join Date
    Jan 2010
    Location
    Posts
    59
    Rides
    Thanks for the info Steve. I won't be able to get it out into the sunlight till tomorrow to take closeups but here is another shot I took earlier. I posted in the what is it section but still haven't figured it out for sure. I did, however find one that looks just like it on the net (which I linked to) that has a sticker on the back calling it a "Sportsman 600" for what thats worth.
    Better pics in the morning! Thanks all.
    Tony
  4. #4
    11/30/62 Tote Gote engine. with temp. tank.
  5. #5
    Sams engine other side.
  6. #6
    Richard Trotter's Avatar
    Join Date
    Jun 2008
    Location
    Spanish Fork,Utah
    Posts
    1,889
    Rides
    Nice motor. It it a 6hp? That is an original tote gote clutch, hang onto that.
  7. #7
    Tom S.'s Avatar
    Join Date
    Feb 2008
    Location
    Hillsboro, Ore.
    Posts
    4,640
    Rides
    The tote-goat (or similar) project looks like fun. I like the black B&S motor in the photos, especially the fan shroud w/embossed B&S logo. I really want one of those. Just missed on on e-bay a couple months ago for ten bucks. Dang.
  8. #8
    Senior Member
    Join Date
    Jun 2009
    Location
    lemoore ca.
    Posts
    578
    Rides
    Try the Tote Gote Land site, post some pictures on there, someone may be able to identify it, there also is a page on tote gote frame ID.
  9. #9
    Join Date
    Jan 2010
    Location
    Posts
    59
    Rides
    Wow, that old Tote Gote engine looks pristine. Thanks for the pics. As far as the Tote Gote Land website I looked at the frame id section but mine doesn't match anything so I am pretty sure it isn't an actual Tote Gote. Here is a link to an identical one I found on the internet...it will be the first in the line of pics.
    Pictures by Tule-trooper-tote-gotes - Photobucket
    Mine even has a worn/unreadable sticker on the back that mimics the one that says "Sportsman 600" on his. Mine also has side screens that I removed to get a better look at things. I don't however have any bracing that would go alongside the engine but that looks to be removeable on the one pictured.
  10. #10
    Join Date
    Jan 2010
    Location
    Posts
    59
    Rides
    Here are the close up pics of the jackshaft arrangement as requested by Steve.
    After cleaning it up a little and squinting just right I was able to make out "Sportsman 300" on the tag...so its not quite the same as the other one I found on the net but definitely the same manufacturer...just wish I new whom that might be?? Thanks again for all the help.
Similar Threads
  1. Tote gote vintage mini bike,torque converter belt.
    By ebay in forum eBay Mini Bikes
    Last Post: 10-10-2010, 07:10 PM
  2. TOTE GOTE OEM engine mounts Vintage minibike
    Last Post: 03-13-2010, 11:20 AM
  3. Replies: 0
    Last Post: 03-01-2010, 08:50 PM
  4. TOTE GOTE OEM engine mounts Vintage minibike
    Last Post: 02-10-2010, 11:00 PM
  5. Mini Bike Tote Gote Briggs & Stratton Engine Motor
    Last Post: 11-14-2009, 09:22 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
