Results 1 to 10 of 10
  1. #1
    Senior Member vinny b's Avatar
    Join Date
    Feb 2007
    Location
    Brunswick Ohio
    Posts
    177
    Rides
    Jackshaft speed calculator
    do you guys know how or where to look to find out speed calculations if a jackshaft is going to be in use? Thanks....Vince
    Email: vbb71@roadrunner.com
  2. #2
    Senior Member 65ShelbyClone's Avatar
    Join Date
    Mar 2007
    Location
    Antelope Valley, SoCal.
    Posts
    2,440
    Rides
    If you know the gear ratios and tire circumference, you don't need a calculator....
  3. #3
    Join Date
    Feb 2007
    Location
    Brunswick Ohio
    Posts
    177
    Rides
    Here is what I have
    Thanks.
    What I have is as follows:
    10 tooth clutch--to--22 tooth jackshaft input--to--10 tooth jack shaft output--to--60 tooth axle sprocket on a live axle with 16" tires.
    Thanks for any help.....Vince
    "not looking to go fast, I would rather have some torque"
  4. #4
    Hello
    Join Date
    Jul 2007
    Location
    Deep East Texas
    Posts
    4,011
    Rides
    Check the first post in this thread New Member Here
    With the gears you have, I would guess you would get 15-20mph, and you will have all kinds of torque.
  5. #5
    Junior Member
    Join Date
    Jan 2008
    Location
    boston
    Posts
    Rides
    I agree with JimH
    my calculations for 3000-3600 rpm on the engine is about 11-16 mph. You are geared down 2.2 to 1 from your clutch sprocket to your 10 tooth jackshaft sprocket. You are geared down 6 to 1 from that 10 tooth jackshaft sprocket to your 60 tooth wheel gear. Your 16 inch wheel has a circumference of pi x D (the 16 inch diameter), which is about 50 inches. So your bike moves 50 inches every time the back wheel rotates one full revolution. Your clutch sprocket needs to turn about 13.2 times (6 x 2.2) to turn your wheel once, and have move you the 50 inches.
    So overall that is a pretty good bit of reduction. So your speed is low, but your torque (power) is high.
    You can get rpms for your engine off the Tulsa Engine Warehouse website under the link for engine line drawings.
  6. #6
    Join Date
    Feb 2007
    Location
    Brunswick Ohio
    Posts
    177
    Rides
    Excellent. Thank you!!!!!
    Awesome guys. Thanks a lot. It's gonna be for a homemade three wheeler and I am 300+ pounds. All I really want to do is ride some trails if I ever find a place.
  7. #7
    Junior Member
    Join Date
    Dec 2007
    Location
    Troy, Oh
    Posts
    Rides
    Vinny
    I got 12.6 mph with the gearing and tire size you stated @ 3500 engine rpm.
    You should have a stumpuller.
  8. #8
    Join Date
    Feb 2007
    Location
    Brunswick Ohio
    Posts
    177
    Rides
    Thanks--
    I hate to be a simpleton guys, but can you show me how you figure this so I can plug in different values in the future instead of me keep asking.
  9. #9
    Join Date
    Feb 2007
    Location
    Brunswick Ohio
    Posts
    177
    Rides
    Thanks Gary
    Your calculator worked excellent. Thanks for your time!!!!!!!
  10. #10
    Anyone want to help me figure out how to calculate the gear ratio and estimated top speed of mine:
    13 tooth clutch to a 18 tooth jack shaft input to a 9 tooth jack shaft output to a 36 tooth axle sprocket on a tire with a 33" circumference.
    It's powered by a stock B&S 5 HP, muffler removed and replaced with a straight 12.5" header, with governor still in place.
    In addition to having an answer, I'd also like to learn how to do all the calculations.
Similar Threads
  1. Two speed jackshaft
    By Larrynsteph in forum General MiniBike Talk
    Last Post: 10-27-2010, 10:58 PM
  2. no 2 speed jackshaft
    By spendinit in forum General MiniBike Talk
    Last Post: 09-19-2010, 04:40 PM
  3. 2 speed jackshaft
    By Bonanza Bryan in forum General MiniBike Talk
    Last Post: 01-20-2010, 06:58 PM
  4. 2 speed jackshaft
    By djm2475 in forum General MiniBike Talk
    Last Post: 10-17-2009, 01:47 PM
  5. Speed Calculator
    By minidragbike in forum General MiniBike Talk
    Last Post: 03-24-2007, 03:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
