Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Senior Member
    Join Date
    Nov 2010
    Location
    Idaho
    Posts
    Rides
    Bad Dog frame kits
    I have a thread for building a mini for my 6yr. girl. I was thinking of one for myself. I was surfing the web & found some large frames made by Bad Dog. I like the idea of the larger frame & tires. I was also looking at the Trail Sport Buffalo. They both cost abit more at 500 to 700 for a no engine kit. I was thinking an 11hp HF clone for power or the 6.5 with a GTC torque converter.
    This bike woud double as a hunting bike. It is alot of money for a mini bike But the cost of a motorcycle or 4wheeler is alot more !!!!!! Do you think this would make a good trail bike?
    How would the torque converter work compaired to the larger engine? Not so much for speed but climbing power?
    John
  2. #2
    Senior Member COWBOY's Avatar
    Join Date
    Oct 2009
    Location
    House Springs, MO just outside St.Louis
    Posts
    390
    Rides
    you have more info on these
  3. #3
    Senior Member korndog's Avatar
    Join Date
    Apr 2010
    Location
    Thousand Oaks, CA
    Posts
    1,927
    Rides
    Hey Jeep
    There are a couple of guys here with the big-frame Bad Dog. Yes, get it! Like you said; it's practical....
  4. #4
    Banned
    Join Date
    Dec 2009
    Location
    Oklahoma
    Posts
    5,342
    Rides
    Bad Dog kits are high rent but a nice unit! The balloon tire model with a big engine and a TAV would be ideal for an all around rider, it would also be great out on the trails! I recently bough some items from BD and there was a small problem and they went above and beyond to make me happy! Great folks to deal with!
  5. #5
    Senior Member
    Join Date
    Nov 2010
    Location
    Idaho
    Posts
    Rides
    Quote Originally Posted by COWBOY View Post
    Bad Dog Enterprises - Mini Bikes, Mini Choppers, Parts, Kits & Assemblies
    John
  6. #6
    Senior Member
    Join Date
    Nov 2010
    Location
    Idaho
    Posts
    Rides
    It sounds like the bad dog might be a good choice then. Does anyone have info on the trailsport Buffalo ? It looks less traditional but still nice.
    John
  7. #7
    steven Durham's Avatar
    Join Date
    Jan 2008
    Location
    Portland , Oregon
    Posts
    8,855
    Rides
    Smile Mixed bag of questions.
    Quote Originally Posted by jeepster360 View Post
    John
    Big tires don't make a good trail bike, and a big engine won't climb hills if not geared properly. A torque converter is better than a clutch but most torque converters are speed sensitive and allow free wheeling on steep grades. A trail machine should have a Torque sensitive drive system so you don't free wheel down the steep hills with the load on the machine.
    First in consideration is gearing for the type of terrain you will be hunting in and a big second is having a proper spark arrestor. You might try looking for a tote gote or seminar type of machine usually not very flashy but they get the job done.
    Steve
  8. #8
    Senior Member
    Join Date
    Nov 2010
    Location
    Idaho
    Posts
    Rides
    Big tires don't make a good trail bike ? Can you elaborate on this some? I could see that the super large 20-22 incher might be a bit much but i would think the larger tires would help with ground clearance & they should help the ride since there is no suspension on the Bad Dog or Buffalo.
    I understand that the bike needs to be geared correctly for the trail & not setup for top speed. A bigger engine would add better low end just because it has more power to begin with, so you could gear alittle higher right? Is there a drive system that allows compression braking for a mini bike setup? Don't the clutch & converter both free wheel down hill ? I read somewhere about a type of 2 speed jack shaft or something also.
    Good info here. I love this place
    John
  9. #9
    Join Date
    Jan 2008
    Location
    Portland , Oregon
    Posts
    8,855
    Rides
    Hi John : Of course the clutch free wheels as does the standard torque converter. The driven half of the torque converter is what designates the type of converter by using a spring that pushes the movable face of the driven half closed and shifting back to a lower gear ratio as engine rpm is reduced this in effect is compression breaking a good thing if your loaded going down a hill. Torque sensitive clutches have inter twined ramps that are held closed by it's spring and the spring is over ridden by the torque sensed by the rear wheel, as torque is lessened the engines rpm stays matched to the throttles demand and as torque is sensed like a hill the engine begins to slow down and the rider is then able to increase the throttle position to keep the power on.
    One bike that is a great trail bike is the Tule Trooper it has the speed sensitive torque converter and a James 2 speed Hi-Lo gear box. In low gear its like a Tote Gote geared low and in High it's like a big wheel mini bike . Most Tule Troopers came with a 5 HP Briggs engine.
    The two speed jack shaft is a speed option not very controllable As for ground clearance yes it is important the big tires on the Bad Dog look like flotation in sand or mud is their main purpose. As far as suspension goes if the two machines your looking at don't come with a suspended model keep looking.
    Steve
  10. #10
    Senior Member DZLBIKE's Avatar
    Join Date
    Jun 2009
    Location
    Foristell, Missouri
    Posts
    1,870
    Rides
    Look for some of these for good off road deer haulers.
    Tote Gote
Similar Threads
  1. Minibike kits
    By Mika in forum General MiniBike Talk
    Last Post: 04-24-2011, 07:26 PM
  2. New taco 22 kits $395
    By Tacojoe in forum General MiniBike Talk
    Last Post: 01-05-2011, 01:19 AM
  3. How many guys buy frame kits?
    By PiperDriver in forum General MiniBike Talk
    Last Post: 06-14-2010, 11:58 PM
  4. Aftermarket CVT kits
    By Oldschool in forum Doodlebug MiniBikes
    Last Post: 11-17-2009, 12:51 PM
  5. N2O kits
    By 1stlegendtx in forum eBay & craigslist
    Last Post: 08-22-2009, 12:55 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
