Results 1 to 8 of 8
  1. #1
    Junior Member
    Join Date
    Aug 2013
    Location
    New York
    Posts
    Rides
    Baja Warrior Minibike project- motorcycle engine
    My friend has what I think is a Baja Motor Sports | Baja Warrior Mini Bike in his barn with something wrong with the engine. I want to get rid of the engine and get a 1 or 2cyl Japanese motorcycle engine, from a 70's or 80's bike and throw it in the frame. I have seen a picture before of a minibike from the 70's at a dragstip with a Honda CB750 4cyl engine. I want to get like a 200-400cc engine with around 30-40hp, do some burnouts, and a little bit of offroading. Has anyone ever seen something like this done and if its possible? I also was looking at a Briggs and Stratton vtwin engine and thought that might be good.
  2. #2
    Welcome to the forum Aaron I would say unless you have welding and fabrication skills I would just get a new engine from Harbor Freight and maybe a TAV and have some fun with it
    "Failure is always an option"
  3. #3
    Junior Member
    Join Date
    Aug 2013
    Location
    New York
    Posts
    Rides
    Quote Originally Posted by Harleys Papa View Post
    I have acces to two people with fabrication, welding and machining skills.
  4. #4
    Senior Member MikeBear's Avatar
    Join Date
    Jul 2010
    Location
    Mid-Michigan
    Posts
    1,431
    Rides
    Quote Originally Posted by AaronNY View Post
    Got access to a hospital?
    Because you are going to need it to put such a high-output motorcycle engine on a CHINA bike with no experience...
    Those bikes can barely stay together with all parts with a 6.5hp engine. I couldn't even imagine riding one with a 40hp engine. Guaranteed death on wheels.
  5. #5
    Junior Member
    Join Date
    Aug 2013
    Location
    New York
    Posts
    Rides
    Challence accepted.
  6. #6
    I almost crashed my Puma bike, which is like the Baja, a few minutes ago. That's with a 6.5 hp engine and a torque converter. Didn't realize the grass was wet from the dew already and wet off road tires on pavement with a rear brake only don't mix
  7. #7
    Junior Member
    Join Date
    Aug 2013
    Location
    New York
    Posts
    Rides
    Im pretty sure I found a replacement 6.5hp engine from Harbor Frieght for 100$ so that might be an option. Arent the wheels on a Baja atv wheels, so I could fit a front disc brake on there and get some moped or something rear shocks on it.
  8. #8
    How would you mount the caliper? You'd be better off using another rear wheel assembly in the front to have an additional drum brake. From experience, I would advise you to keep the Baja relatively simple without a ton of modifications and get something fast if you want something fast. You can do about 40 mph or close with a pretty much stock 6.5 hp and torque converter. Do some engine mods and you can do 40 and still have some low end. Maintaining these bikes and keeping them running isn't bad. But once you throw a bunch of things not made for each other together, it can become a pain.
Similar Threads
  1. Baja Warrior engine swap... Tecumseh HM80
    By Bluethunder3320 in forum Doodlebug MiniBikes
    Last Post: 02-04-2013, 08:43 PM
  2. Baja Warrior/165/200 Frame less engine
    By rpm in forum Mini Bikes & Parts WANTED
    Last Post: 10-18-2012, 01:11 PM
  3. Will This engine work for Baja Warrior
    By Dcdoc in forum Honda / Clone / Predator Engines
    Last Post: 12-29-2011, 07:00 PM
  4. Baja Warrior RACER Project
    By MiniBike Paul in forum Mini Bike Parts
    Last Post: 07-02-2011, 02:08 PM
  5. Baja Warrior 200cc Engine Idle Stall
    By Justin9 in forum Honda / Clone / Predator Engines
    Last Post: 06-10-2011, 12:42 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
