Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Senior Member
    Join Date
    Jul 2009
    Location
    Southeastern PA
    Posts
    4,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    How to remove a wheel from an axle?
    How do I remove the wheel from the axle? I got new tires and I need to take the wheel off to put them on, so how do you get it off? Is there a special trick or tool needed? Any help will be greatly appreciated.
  2. #2
    Banned
    Join Date
    Dec 2009
    Location
    Oklahoma
    Posts
    5,342
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Throttleproblems View Post
    What minibike are you working on?
  3. #3
    Senior Member joekd's Avatar
    Join Date
    Oct 2009
    Location
    CT
    Posts
    2,226
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Depends on how your kart is setup, on mine it's as simple as removing the nut on the end of the axle and sliding it off
    Pics might help
  4. #4
    Senior Member
    Join Date
    Jul 2009
    Location
    Southeastern PA
    Posts
    4,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Supernova- Im working on my kart
    Joekd- It has a live axle that has threaded ends which the nut goes on, I removed the nut, but no matter hat I do I still cant get the wheel to budge.
  5. #5
    Banned
    Join Date
    Dec 2009
    Location
    Oklahoma
    Posts
    5,342
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If it is a keyed axle you will want some wd40 and a rubber hammer if they dont just slide right off, if you dont have one use a board and a regular hammer just dont hit it too hard or in the same place twice! Go all the way around as many times as it takes to remove it and put some axle grease back on when putting them back on to make it easier next time!
  6. #6
    Senior Member
    Join Date
    Jul 2009
    Location
    Southeastern PA
    Posts
    4,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Correct, it is a keyed axle. So, rubber hammer + wd40 = my wheel should come off?
  7. #7
    Banned
    Join Date
    Dec 2009
    Location
    Oklahoma
    Posts
    5,342
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    If there are no lock collars and you can see the shaft in the wheel hub then it should in theory come off with some coaxing, just be as gentle as possible so as not to destroy anything!
  8. #8
    Senior Member
    Join Date
    Jul 2009
    Location
    Southeastern PA
    Posts
    4,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    what is a lock collar?
  9. #9
    Banned
    Join Date
    Dec 2009
    Location
    Oklahoma
    Posts
    5,342
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Like a clamp or the collar on a clutch with the set screws, they go on a keyed shaft to lock things in place or limit movement, chances are you have some on that kart somewhere on the rear axle. Your axles look like they are grooved on the end for a washer and clip to hold the wheel on, if those are off then the wheel should come off as I saw no lock collars in the pics of your kart. They probably just are frozen by rust and time, be patient and let the wd40 work and keep checking and spray some more!
  10. #10
    Senior Member The Restore Kid's Avatar
    Join Date
    Jul 2007
    Location
    Michigan
    Posts
    11,695
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by supernova View Post
    Yeah thats about the best you can do is soak the hell out of them and let the stuff sink in.. You can heat the hub with a torch and try to swell it up slightly bigger to release it's grasp on the axle too..
    If ya get em off and go to put the new ones on... Not only grease them but use a file to run over everything and make sure there are no burs, rust deposits, that kind of thing on the axle or keyway.. AND inside the wheel hub.. That kind of stuff causes problems too.. If it doesn't slide right on and off like nothing, something is wrong.. And beating on them just makes stuff worse.. Gentle taps trying to get it off for the first time is one thing.. but after it's off, you should never have a problem ever again if ya do it right..
Similar Threads
  1. Recommend/find me a live axle hub+wheel
    By Cotmullion in forum Mini Bike Discussion
    Last Post: 01-14-2011, 02:34 PM
  2. vintage minibike axle wheel spacers ruttman taco ?
    By ebay in forum eBay Mini Bikes
    Last Post: 01-28-2010, 05:30 PM
  3. Replies: 0
    Last Post: 10-28-2009, 02:00 PM
  4. Replies: 0
    Last Post: 03-09-2009, 07:00 PM
  5. Replies: 0
    Last Post: 10-14-2008, 11:10 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
