Register FAQ Members List Calendar Mini Bike Parts Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Honda / Clone Engines
Reply
Thread Tools Display Modes
Old 01-03-2010, 12:16 PM   #11 (permalink)
also i found someone to mill my head. What is a safe amount to mill off the head that can be used with a flattop piston?
845mx5 is offline   Reply With Quote
Old 01-03-2010, 03:03 PM   #12 (permalink)
Senior Member
Phantom's Avatar
Quote:
Originally Posted by 845mx5 View Post
that didnt really help. i guess i was unclear. What do the numbers alongside the flattop pistons represtent? a different bore? or is it taller, meaning it would up te compression?
You mean the numbers stamped in the piston? If those are what you mean then they indicate if the piston is std, overbore .010, .020, etc
__________________
Never ague with a idiot they will bring you down to his/her level and beat you with experience.
Phantom is offline   Reply With Quote
Old 01-03-2010, 03:05 PM   #13 (permalink)
Senior Member
Phantom's Avatar
.050 with stock cam.
__________________
Old 01-05-2010, 07:16 PM   #14 (permalink)
Supporting Speed Nut!
minidragbike's Avatar
Running to much compression with a stock head, your gonna end up loosing more power than your gaining. Especially with a stock cam.
__________________
Check Out My Videos Below!!!
http://www.youtube.com/user/minidragbike
Facebook Page Below
http://www.facebook.com/Minidragbike
minidragbike is offline   Reply With Quote
Old 01-05-2010, 07:27 PM   #15 (permalink)
Senior Member
Phantom's Avatar
^^ Very True.
__________________
Old 01-05-2010, 08:17 PM   #16 (permalink)
What would cause me to lose power? If i milled .050 off of the head, flattop piston and stock cam, where would i loose power? Would i need to open up the valves? I plan on getting a better cam but that will be some time from now. I have a couple hundred id like to spend and get the best bang for my buck. What would you suggest? Milling the head will be free.
Old 01-05-2010, 09:12 PM   #17 (permalink)
Senior Member
Phantom's Avatar
Ok since you are gettin a cam, here is a common recipe 265 cam, 1.2 rockers, milled head, 22mm mikuni, flattop piston, billet rod and other odds and ends and you should be good to go, give it a good gearing and hold on. Oh and what causes you to lose power with stock cam may MDB correct if i'm wrong but its duration.
__________________
Old 01-05-2010, 09:17 PM   #18 (permalink)
The factory carb already is restricting the stock head flow. Adding more cylinder pressure just makes the flow even harder to get in there.
__________________
Facebook Page Below
Reply
Lower Navigation
Tags
build?, compression, high
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
to much compression No-Limit Engines and Modifications 14 06-08-2009 11:33 AM
Compression Question LouieM Tecumseh Engines 1 06-04-2009 12:09 PM
2 stroke compression blownengine Engines and Modifications 14 01-25-2009 11:57 PM
How to get back compression ? Rapini Project Logs 4 08-18-2008 09:14 AM
Engine Compression oldsledz General MiniBike Talk 2 10-28-2007 03:10 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0 RC2 Copyright 2006-2009 OldMiniBikes.com / OMB Group LLC
no new posts
