Register FAQ Members List Calendar Mini Bike Parts Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Honda / Clone Engines
Reply
Thread Tools Display Modes
Old 03-14-2010, 12:51 AM   #1 (permalink)
Member
Engine Won't Start
Just finished my build and it won't start. HF 6.5 with CM cam, 26lb springs, rod, flywheel, adv. 4 deg., head milled .065, ported (remove sharp edges and blend valve gides), NGK plug, AFG header, carb bored .627, main .036, idle .020, no choke, throtle shaft thined, K&N style cleaner. It will pop and sometimes backfire through carb. When I adjusted valves could it be that I was on the compresion relase? Please help. I ran out of time and had to quit for the nite. Its going to drive me crazy until its fixed.
Hot Rod is offline   Reply With Quote
Old 03-14-2010, 06:15 AM   #2 (permalink)
hahahaha
check the flywheel key.
where you at TDC when you set the valve lash?
are the dots on the crank and cam lined up?
Strigoi is offline   Reply With Quote
Old 03-16-2010, 12:04 AM   #3 (permalink)
Member
I got it running but it bogs off idle. Could it be my gas 89 otc. with 10-1 compression or the glued in air jet? After bog you better be holding on it runs gooooooooood!
Reply
Lower Navigation
Tags
engine, start, won't
Thread Tools
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bought a used mini bike with H35 engine. Won't start, what to try 1st? zer0vette Tecumseh Engines 34 09-30-2009 07:33 AM
6.5 engine won't start sam63079 Baja Motorsports - Doodlebug MiniBikes 0 07-24-2009 09:02 PM
Engine Wont Start! Boondox Honda / Clone Engines 8 07-03-2009 05:59 PM
Wanted Electric start engine shoe Mini Bikes & Parts WANTED 0 10-06-2008 11:39 AM
my engine wont start. minibikekid16 Engines and Modifications 1 05-18-2008 05:30 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0 RC2 Copyright 2006-2009 OldMiniBikes.com / OMB Group LLC
no new posts
