Register FAQ Members List Calendar Mini Bike Parts Search Today's Posts Mark Forums Read
Go Back   OldMiniBikes.com Forum > General > Engines and Modifications > Honda / Clone Engines
Reply
Thread Tools Display Modes
Old 01-07-2009, 10:43 AM   #1 (permalink)
Senior Member
johnf.357's Avatar
Question installing a fuel cell for a clone
I want to use a walbro 22 mm carb for my kart,so will I have to get rid of the gas tank on the clone and go with a pumper.but I do not know anything about them,other than the basics.
can someone tell me if it is complacated to set up?
What makes the pump draw the gas to the engine?
And the cost I can expect to change it??
Thanx for your help!!
__________________
Bushmaster carbine .223,acp 45acp & .357 Mag. Rules @Highland Gun club,Foster Rhode Island and Hope pistol & revolver club,prov.RI
Rides
7 hp robin subaru engine chopper
6.5 clone on a coyote free roller race kart
PCR Jaguar race kart,converted to 4 cycle set up
johnf.357 is offline   Reply With Quote
Old 01-07-2009, 10:58 AM   #2 (permalink)
Senior Member
Motra's Avatar
The pump is operated by engine pulses. The alternating positive and negative pressures move a diaphragm back and forth. That combined with some reed valves pumps the fuel. Check out this link: Affordable Go Karts - Fuel Pump Setup
Motra is offline   Reply With Quote
Old 01-07-2009, 11:09 AM   #3 (permalink)
Senior Member
Stang's Avatar
Cost is fairly minimal for the actual pump, but you either have to machine a place to pulse from or buy an intake with a provision for it. You can use a PZ22 and not use a pump, and actually for alot of cases it is probably not necessary unless you are doing some head work and adding a cam. If the motor is mostly stock or slightly modified with bolt ons it can be gravity fed.
Most people pulse pumps from their crankcase or intake.
__________________
Rupp TT500 - New Project!
Ruttman Spyder - GX200 Project
HPE Muskin CAT R4005
Ruttman 390
Clone Block, Head (-.100, port matched and short side radius work), ARP Studs
Rotating Assembly: Honda Crank/Piston (Flattop, Cryo treated), ARC Rod, Flywheel (30deg)
Valvetrain: CAM (NR 320 Grind), Stainless Valves, EES Springs, Aluminum Retainers/Locks, Chromoly Pushrods, 1.3 Billet Roller Rockers
Induction & Exhaust: AGK Billet Intake, Mikuni 34mm Flatslide & Fuel Pump, Cloth Filter, 1.5" Header
Stang is offline   Reply With Quote
Old 01-07-2009, 11:15 AM   #4 (permalink)
hahahaha
if you need a place to mount a fuel pump, this guy sells plates on ebay. i picked one up from him and it's pretty nice. you just need to drill the holes to mount it. he doesn't have any on ebay currently, but i'm sure you could just contact him. he's friends with one of the members (briggs_boy) on here..
eBay Motors: GX200 GX160 Honda Clone Engine Plate Fuel Pump Mount (item 230315232892 end time Dec-29-08 07:20:54 PST)
Strigoi is offline   Reply With Quote
Old 01-07-2009, 12:40 PM   #5 (permalink)
Senior Member
johnf.357's Avatar
fuel cell
Ok
so are u saying here that,I can use the tank on motor set up,or are u saying that I have to go with a fuel cell up front(for this type of carb) but do not need anything else that it will flow by gravity/
Thanx to all for your input,and not giving me %#!x because it's for a kart!!
__________________
Rides
Old 01-07-2009, 01:39 PM   #6 (permalink)
Senior Member
Stang's Avatar
Ahh didn't see it was for a kart. I would imagine the fuel cell is a little further away up by the driver or so. In that case you will probably need one. Sorry bout that!
__________________
Ruttman 390
Old 01-07-2009, 02:53 PM   #7 (permalink)
Senior Member
johnf.357's Avatar
no problemo
it's all good,thanx for your time stang...
__________________
Rides
Old 01-07-2009, 04:33 PM   #8 (permalink)
Senior Member
Stang's Avatar
No problem! Just didn't want ya to do more then what was necessary. What kinda kart you puttin this on? Man if I had more room, I'd like to get a vintage kart :D
__________________
Ruttman 390
Old 01-09-2009, 05:39 PM   #9 (permalink)
Junior Member
its much easer to pulse off of the valve cover and you can do it with a drill.
The first one I did, I took off the tank and bolted the pump to one of the old tank mounts.
see pictures here Clone Engine Specifications
in the "gallery" section.
Later,
Gundy
4Racers.com
mrdlg2u is offline   Reply With Quote
Old 01-09-2009, 07:48 PM   #10 (permalink)
Senior Member
johnf.357's Avatar
It's a 1990 margay kart
the kart is a 1990 margay not sure if that quailfies as vintage??
__________________
Rides
Reply
Lower Navigation
Tags
cell, clone, fuel, installing
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0 RC2 Copyright 2006-2009 OldMiniBikes.com / OMB Group LLC
no new posts
