Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Senior Member
    Join Date
    May 2009
    Location
    Taylor,MI
    Posts
    484
    Rides
    18cc head vs.14cc head
    which head flows better and make the most power An if I do get a 18cc what is the most I can mill it will a flat top piston before I fun in to clearance issues
  2. #2
    Senior Member
    Join Date
    May 2009
    Location
    Taylor,MI
    Posts
    484
    Rides
    14cc vs. 18cc head
    should I go with a 14cc head or 18cc, and why? I keep looking on agk site and shane Loves those 14cc heads, But Russ at Nr says a 18cc head makes more power and flows betterWhat is you take on this,and let say both heads are just bolted on,no milling of porting. Then if you ported and milled
  3. #3
    Banned
    Join Date
    Apr 2009
    Location
    USA
    Posts
    1,389
    Rides
    had the same issue you know depends who you talk to. things to consider also are coil bind and valvetrain geometry? these were just a couple issues that came up.
  4. #4
    Senior Member
    Join Date
    May 2009
    Location
    Taylor,MI
    Posts
    484
    Rides
    heads
    Quote Originally Posted by Tacoterminator View Post
    This is 1 very good topic and I have asked myself and other's the same thing.
    Russ has the milling machine and the flow bench.
    As far as I know Shane likes the smaller combustion head 14cc and does not port the heads. He does get them milled. I may be incorrect? However, when I purchase the new motor I have chosen Russ to do the work. If the fuel is gasoline the compression does not need to be 12.5-1 ---- if it is Alcohol it may need the additional compression and smaller head.
    I am spending my money on the 18cc head that comes with the motor and porting and milling and going with gasoline. The package is $1300 sending out my gx-200 to Russ and will eliminate a 18K Gold date quickset Rolex watch with an black aligator band this week to do the hop up. Charles and I went over this. I do not want the clear buring fuel anywhere near my balls. If it were a go kart engine I would go alcohol and 14cc milled and ported. It comes down to how much you like your balls....lol
    great question
    Rolex perfect paid $3200- cash and very rare in 8.5 of 10 condition. It's an over 40 watch it's not for the 25 year old wearer... I have two others ones to keep! PM me if your want the best...or email flatlinefilmsllc@aol.com/
    It would take a year to find a soild gold non-day 18K quickset again. It is grandfather owned and perfect.... Now it's a new motor!
    TT OUT!
    Shane also, has a ported and milled 14cc head, That is why I am stuck I can get 110 oct all day long here in Michigan, it is at at every other gas station. When I talked to shane He did say the 14cc flowed real good. I have no clue what to do I will wait for mdb to step in. I want that high compression for that down low grunt, and also want to make about 15 hp. we will see, also you are right Shane has his in a kart,we are using minibikes I need more in for lets keep the topic alive
  5. #5
    Banned
    Join Date
    Apr 2009
    Location
    USA
    Posts
    1,389
    Rides
    speaking of hp, have you checked into parsons racing. u know they have some nice looking race builds pushing 20-38hp looks ready to go.
  6. #6
    Senior Member
    Join Date
    May 2009
    Location
    Taylor,MI
    Posts
    484
    Rides
    So I should run the 14cc head? Also I females, that advice I can give you. Just ask
  7. #7
    Supporting Speed Nut! minidragbike's Avatar
    Join Date
    Nov 2006
    Location
    LYNWOOD
    Posts
    11,068
    Rides
    If the heads are box stock the heads flow the same. If you add bigger valves and do nothing else the 18cc head flows more. The bigger valves will has slight flow blockage, which in turn you see people say that they unshroud the valves. To unshroud the valves is just making the area around the valves unblocked to let the air/fuel mixer that's trying to get around the valve head get into the combustion chamber better.
    If you are plan on modifying the head at all the 14cc head is best. You can unshroud it and end up with 16cc, even with the biggest valves you can put in it. With the bigger 18cc head with those same big valves you will walso have to unshroud the head, so you will end up with a 20cc head. Or if you just go a little bigger on the valves you will still be at 18cc.
    These are two seperate 14cc head with very big valves in it. 31mm intake 27mm exhaust, the top head isn't unshrouded yet, and the bottom head is unshrouded a lot. The bottom head is now 18cc, but flos way better than if i started with a original 18cc head. Look at the difference. With this size valves all heads, even the bigger 22cc head has to be unshrouded.
  8. #8
    Senior Member
    Join Date
    May 2009
    Location
    Taylor,MI
    Posts
    484
    Rides
    once again Thanks you ,I am gonna deal with Charles and Shane, This is also for a straight line bike. I love Drag racing
  9. #9
    Senior Member Solo Cali's Avatar
    Join Date
    Oct 2007
    Location
    Hesperia CA.
    Posts
    6,641
    Rides
    MDB you still speak with Choo Choo on a regular ?
  10. #10
    Senior Member npatton19's Avatar
    Join Date
    Jan 2009
    Location
    Ontario, Canada
    Posts
    213
    Rides
    I have an 18cc head milled 0.040" and has been slightly unshrouded around the valves. It also has a 26mm intake valve with an enlarged seat for more flow, billet steel retainers with hardened locks and lash caps. Your choice of 18pd or 26pd springs with or without shims for more pressure. Lastly has a custom port job I did myself, all I tried to do was open up the short side radius a fair amount and then slightly enlarged port size to match AGK intake manifold. I have run this head with a mikuni and the motor is full of torque, send me a PM if your interested and make me an offer.
Similar Threads
  1. 14cc Head on a 6.5
    By RobK in forum Honda / Clone / Predator Engines
    Last Post: 04-06-2011, 09:58 PM
  2. 14cc head
    By cncd11 in forum Honda / Clone / Predator Engines
    Last Post: 01-05-2011, 11:16 PM
  3. what head would flow better? 14cc or 18cc
    By wildman500 in forum Honda / Clone / Predator Engines
    Last Post: 07-23-2010, 04:30 PM
  4. is a gx160 long head 18cc or 14cc
    By chadillac in forum Honda / Clone / Predator Engines
    Last Post: 12-30-2009, 02:56 PM
  5. 18cc head
    By boogyman in forum Honda / Clone / Predator Engines
    Last Post: 07-21-2009, 10:03 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
