Results 1 to 6 of 6
  1. #1
    Member matstang's Avatar
    Join Date
    Jan 2008
    Location
    Farmington, Utah
    Posts
    89
    Rides
    Honda G100 Governor?
    Hello, been a while since I've posted, but I've come across a good little lawn edger that has the Honda 2.2HP G100 motor on it. It's having a hard time idling and accelerating. I've cleaned the carb, adjusted the air/fuel mixture checked for vacuum leaks. The only thing I can think is that the PO has pulled the governor arm off the shaft and possibly reinstalled it with the shaft turned in the wrong direction. I've searched and cannot find the proper positioning of this shaft. Any Honda pros out there? This thing looks brand new and I'd like to see about getting it running! Thanks!
  2. #2
    Join Date
    Jan 2008
    Location
    Farmington, Utah
    Posts
    89
    Rides
    Push the governor lever all the way to either direction (full throttle or full idle) and turn the governor shaft fully to that same direction.
  3. #3
    Senior Member Motra's Avatar
    Join Date
    Mar 2008
    Location
    SLC, UT
    Posts
    1,920
    Rides
    You loosen the governor arm and move it to the full throttle position, then you rotate the governor shaft the same direction til it stops, then without disturbing this position you retighten the pinch bolt. In your second picture I noticed that the pinch bolt is missing. Did you remove it or was it not there? If it's missing then I'd say that's definately your problem.
  4. #4
    Join Date
    Jan 2008
    Location
    Farmington, Utah
    Posts
    89
    Rides
    Quote Originally Posted by Motra View Post
    No it's there, just wasn't installed in the pic. If you look close you can see the bolt sitting in the bottom tray of the edger! Thanks for the response!
  5. #5
    Join Date
    Jan 2008
    Location
    Farmington, Utah
    Posts
    89
    Rides
    Just wanted to update the progress on this edger. It almost got the best of me, but I decided one last resort was to just do a visual on everything I could. I removed the head and was it black! Running very rich! I could see on the head where the valve had been hitting, so this led me to think there was something wrong with the valve. I removed the 'valve service' plate and there it was...the valve spring retainer had come loose. Reinstalled everything correctly, cleaned the head and it fired right up and runs...like a Honda!
  6. #6
    Senior Member milo raptors's Avatar
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Rides
    hahaha good job man honda is one of da best
Similar Threads
  1. governor on honda gc 190
    By jaybirdy in forum Honda / Clone / Predator Engines
    Last Post: 08-20-2014, 10:38 PM
  2. G100-G100 Clone
    By Dudlydoodleright in forum Honda / Clone / Predator Engines
    Last Post: 10-27-2010, 03:37 AM
  3. ***great little honda flathead sidepooper G100***
    By edwin in forum Mini Bike Parts
    Last Post: 10-26-2010, 03:55 AM
  4. Governor Removal on Honda Clone
    By F.Wood in forum Honda / Clone / Predator Engines
    Last Post: 04-19-2010, 10:36 PM
  5. Honda GX120 carb/governor linkages and springs
    By johnhos in forum Engines and Modifications
    Last Post: 02-16-2009, 02:41 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
