Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Junior Member
    Join Date
    Oct 2009
    Location
    Orange County Ca.
    Posts
    Rides
    Hot Rod GX390 Clone
    Hello everyone.I need some advice.Iv got a new HF 13HP 390 clone in the box.I want to hop it up a bit but still keep the pull-start if I can?,,so I know there are limits.
    20HP would be nice but maybe Im dreaming,,,what parts do I need to buy to make this a Strong fast fun engine?
    I would like to stay with high end gas for now,and what would be the best clutch?,,what sort of RPM would this engine turn?,, please give me some of your wisdom on 390s
    Im not cheap,and I will try to buy the better parts,,but this is where I need the advice,,,its for a custom mini bike...
    Thanks to everyone for your help,Don
  2. #2
    Banned Strigoi's Avatar
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,009
    Rides
    how much are you looking to spend?
    GX390 parts are not cheap.
  3. #3
    Junior Member
    Join Date
    Oct 2009
    Location
    Orange County Ca.
    Posts
    Rides
    Quote Originally Posted by Strigoi View Post
    Thanks for the reply,well I understand that none of this engine stuff is cheap,and money is not a big issue,but I don't want to waste any on junk parts.I can do my own head work,as Iv been porting heads for years,but I need advice on valves,keeper springs and so on.I have a flow bench but it will be a few months untill I get it setup for the small engines.
    I know Im going to need a piston and rod,,cam,push rods,carb and so on,,,but remember I want to use the pull start,,,so there are limits,,,,so please advice me.Thanks Don
  4. #4
    Senior Member milo raptors's Avatar
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Rides
    as long as the cam your usin has an easy start on it you could pull start it with 15 to 1 compress
  5. #5
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,009
    Rides
    if you want to run regular gas, it would be best to stay around 12-12.5:1.
    here are a couple of sites that you can start checking out for parts.
    NR-Racing.com - check the GX240/270 race parts section
    Affordable Go Karts - Home page - AGK - http://www.affordablegokarts.com
  6. #6
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Rides
    GX390page heres another i here this dude is a true hot roddr
  7. #7
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,009
    Rides
    Clements Racing makes good stuff.
  8. #8
    Join Date
    Aug 2009
    Location
    somewere nice
    Posts
    1,298
    Rides
    yea hes got some bad @$$ lookin Stuff there man i realy like the H beams hes got and they arnt that much more than NR stuff r they
  9. #9
    Supporting Speed Nut! minidragbike's Avatar
    Join Date
    Nov 2006
    Location
    LYNWOOD
    Posts
    11,068
    Rides
    Getting 20hp from a gx390 clone is pretty easy. The regular off the shelf kits should be able to get you there. Just make sure you read up, and learn how to tune carbs. That's gonna rack your brain for at least a few months.
  10. #10
    Junior Member
    Join Date
    Oct 2009
    Location
    Orange County Ca.
    Posts
    Rides
    Quote Originally Posted by minidragbike View Post
    Thank you,,,,Should I change out the piston also,Like a wiseco?..and what is a safe deck hight?
    Who makes the best dragracing clutch with a 1" bore?
    Thanks again,Don
Similar Threads
  1. NEW****GX390 clone 13 hp engine****NEW
    By blkscorpion80 in forum Mini Bike Parts
    Last Post: 01-02-2011, 12:10 AM
  2. GX390 clone questions
    By waltsuz in forum Honda / Clone / Predator Engines
    Last Post: 11-28-2010, 01:38 AM
  3. GX390 clone...... 13hp
    By 440dakota in forum Mini Bike Parts
    Last Post: 02-21-2010, 02:06 PM
  4. my new GX390
    By 71dodge in forum Honda / Clone / Predator Engines
    Last Post: 01-24-2010, 08:19 PM
  5. WTB GX390 Cam
    By JakeSpec in forum Mini Bikes & Parts WANTED
    Last Post: 07-07-2009, 07:20 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
