Results 1 to 10 of 10
  1. #1
    Junior Member
    Join Date
    Jul 2010
    Location
    Cape Cod, MA
    Posts
    Rides
    Newbie with a Mini Baja 6.5 hensim???
    Hi Fellas,
    Just picked up my first ever mini bike a 2006 Mini Baja with a hensim 6.5 195cc engine. It runs smooth at idle but pops and runs like crap when given throttle. I assumed dirty carb but have cleaned it thoroughly 2X with no change and of couse new gas. There is no fuel filter that I can find and I blew air back through anyway. I've tried running it with and without the air filter just in case and changed the spark plug.
    It seems to get too much fuel. Next I plan to check compression. Any Idea what I should get for a reading? I also recall reading about the governor. Should there be any springs attached or should it just flucuate as needed?
    I bought this thinking it'd be a blast for the kids but I fear that if I get it running right I wn't want to share. I'll definitely need to slow it down.
    Thanks for any help.
    Rick
  2. #2
    Senior Member robby12's Avatar
    Join Date
    May 2010
    Location
    Fulton,NY
    Posts
    291
    Rides
    Sound like the carb is put of adjustment if it has low compression it would be hard to start
  3. #3
    Junior Member
    Join Date
    Jul 2010
    Location
    Cape Cod, MA
    Posts
    Rides
    I don't think it's an adjustment and I've cleaned the carb 3X with wire, carb cleaner and air. I'm now wondering if there is suposed to be a spring attached to the black plastic piece that has a rod going to the governor arm and idle adjustment screw that sits on top of carburator. When I rev it up that piece flucuates making it pop and run "jerky" if I hold it from jumping around it smooths right out making me think it may be missing a spring.
  4. #4
    Junior Member
    Join Date
    Jul 2010
    Location
    Cape Cod, MA
    Posts
    Rides
    Never mind I found that it was missing a spring. I took it to a local shop that works on a lot of small bikes and small engines and get this...they GAVE me a Honda 6.5hp motor off a pressure washer that had a bad pump. The motor is exactly the same as the Hensim so now I can either rob parts or replace the engine with the Honda as it is in good running condition. It feels good to luck out once in while.
  5. #5
    Member
    Join Date
    May 2010
    Location
    traverse city, michigan
    Posts
    Rides
    id put the honda in and use the hensim for parts
  6. #6
    Junior Member
    Join Date
    Jul 2010
    Location
    Cape Cod, MA
    Posts
    Rides
    I might do that but the Hensim is running great. Are the any advantages to running the Honda?
  7. #7
    Member
    Join Date
    May 2010
    Location
    Posts
    Rides
    well honda is a really nice quality name brand and im not sure what hensim is.. off brand?
  8. #8
    Senior Member
    Join Date
    Apr 2010
    Location
    Virginia Beach
    Posts
    485
    Rides
    I have two clones, a 5.5 on a mini Baja, and a 6.5 from Harbor Freight. Neither would run worth a darn without the choke at least half way on. I replaced the jet in the carbs with a #90 and they now run fine with the choke all the way off.
  9. #9
    Member
    Join Date
    May 2010
    Location
    Posts
    Rides
    seems like a #90 is a little big for a unmodded clone? does it foul out?
  10. #10
    Senior Member
    Join Date
    Apr 2010
    Location
    Virginia Beach
    Posts
    485
    Rides
    Not at all.
Similar Threads
  1. Baja Mini, Baja Warrior Parts?
    By msgrmv in forum Doodlebug MiniBikes
    Last Post: 05-28-2013, 09:19 PM
  2. Replies: 0
    Last Post: 11-18-2010, 03:40 PM
  3. Need help !!!! Baja mb165 6.5hp hensim engine
    By eman193 in forum Engines and Modifications
    Last Post: 06-06-2010, 01:47 PM
  4. Baja Motorsports Mini Baja
    By cybersphere01 in forum Doodlebug MiniBikes
    Last Post: 05-29-2010, 09:14 AM
  5. Replies: 0
    Last Post: 05-27-2010, 03:20 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
