Results 1 to 5 of 5
  1. #1
    Senior Member
    Join Date
    Apr 2010
    Location
    Virginia Beach
    Posts
    485
    Rides
    Difference Between GX140, GX160, GX200
    Are any of the parts on a GX140 interchangable on a 160 or 200? They're obviously similar, but what are the differences?
  2. #2
    Senior Member
    Join Date
    Jul 2009
    Location
    Southeastern PA
    Posts
    4,526
    Rides
    Quote Originally Posted by RobK View Post
    The Gx160 carb is smaller, along with the stroke.
  3. #3
    Senior Member
    Join Date
    Apr 2010
    Location
    Virginia Beach
    Posts
    485
    Rides
    But is the block the same? Can the cylinder head be used on a 200?
  4. #4
    Senior Member
    Join Date
    Jul 2009
    Location
    Southeastern PA
    Posts
    4,526
    Rides
    I think the 140 head can be used on a 200, but don't take my word for it.
    The block between all of them is different.
    I know for a fact that the 160 head works on a 200 since I'm running one.
  5. #5
    Senior Member cncd11's Avatar
    Join Date
    Dec 2008
    Location
    Riverview Michigan.
    Posts
    493
    Rides
    the 140 head from what i remember will bolt up but you dont want to put it on your engine. The ports and valves are smaller and will kill any performance on the engine. The 160 heads have the same size valves and portsas the 200 engines and smaller combustion chambers so it bumps your compression ratio up which is why they are sought after by the gear heads.
Similar Threads
  1. gx160 flywheel on gx200?
    By detroitdiesel in forum Honda / Clone / Predator Engines
    Last Post: 03-15-2011, 01:59 PM
  2. gx160 head on a gx200
    By Hothead79 in forum Honda / Clone / Predator Engines
    Last Post: 08-29-2010, 12:00 AM
  3. whats the difference betwwen gx169 and gx200 head
    By chadillac in forum Honda / Clone / Predator Engines
    Last Post: 12-04-2009, 01:35 PM
  4. wtb tank and air cleaner honda gx140/gx160
    By jkaiser in forum Mini Bikes & Parts WANTED
    Last Post: 11-14-2009, 09:36 AM
  5. What is the difference GX160/GX200
    By N-gin in forum Engines and Modifications
    Last Post: 11-01-2007, 01:11 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
