Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Senior Member
    Join Date
    Sep 2009
    Location
    Brookville, PA
    Posts
    2,750
    Rides
    FYI the 420cc is 16hp.
    GX390 is 13hp
  2. #12
    Member
    Join Date
    Sep 2012
    Location
    Troy, Texas
    Posts
    Rides
    Quote Originally Posted by rmm727 View Post
    GX390 is 13hp
    FYI, the HF 420cc Predator is rated at 13hp.
    420cc Predator
  3. #13
    Senior Member
    Join Date
    Sep 2009
    Location
    Brookville, PA
    Posts
    2,750
    Rides
    Harbor Freight use to list it at 16hp. Loncin who is the manufacturer lists it at 15hp.
    15 Horse power seriesú║G420F/G420FD - Loncin lndustries
    Duromax blue 420cc ones are 15/16hp as well.
    Harbor Freight lists it as a REPLACEMENT for 13hp engines.
  4. #14
    Senior Member paul_probus's Avatar
    Join Date
    Dec 2011
    Location
    VA
    Posts
    397
    Rides
    @RMM,
    Not trying to argue, but Honda lists its 390 cc as net 11 hp.
    Honda Power Equipment: Honda Generators, Lawn Mowers, Snowblowers, Tillers
    @All
    Not to steal the thread, but does anyone make a flywheel that can handle higher RPM's and still be able to use the Honda 20 amp charging system? I don't care about racing, I would like to build a fat tire bike around the 420 Predator, add on the Honda 20 amp charging system (cheaper to do this than buy the Honda 390 with the charging system) and get additional performance out of it. The only problem is that the couple of places I have looked at performance parts for the 420 cc engine do not have flywheels that can be used with a charging system (I guess because most people building up these engines want to race them). I'd like to be able to keep the starter, run lights and have a 12V outlet. Not looking for 10K rpm capability, but getting to 5K or 7K rpm would be about what I would be looking for.
    Paul
  5. #15
    Senior Member vwfan79's Avatar
    Join Date
    Aug 2012
    Location
    Flushing, MI
    Posts
    2,428
    Rides
    Quote Originally Posted by texasfabguy View Post
    Sorry...
    Small blocks are cheaper to build part for part but you will spend half getting over 20+HP out of a big block over the small block.
    No need to apologize, I'm still new at this and welcome all the new knowledge I can get.
    I do see where your coming from though as with a big block your already half way to the 20hp right out of the box.
  6. #16
    Senior Member texasfabguy's Avatar
    Join Date
    May 2011
    Location
    Conroe,Texas
    Posts
    2,328
    Rides
    Quote Originally Posted by paul_probus View Post
    @RMM,
    @All
    Paul
    11.7 at 3600 but look at the torque it puts out at 19.5.
    On your other....no one makes a billet with the charging magnets. No reason you could not add them yourself though.
  7. #17
    Member
    Join Date
    Sep 2012
    Location
    Troy, Texas
    Posts
    Rides
    rmm727- Gotcha. Thanks for the info. I did notice that at HF the shelf tag showed the 212cc as 7hp instead of the advertised 6.5hp. And my kids have a go kart with a Subaru 169cc and it says it is 6.5hp. Doesn't seem like there is a hp standard on these little power plants.
    texasfabguy- Have You seen anyone that has added the magnets to the billet flywheel? Or is there anywhere that tells how to add them? I was wondering the same thing as paul_probus.
  8. #18
    Join Date
    Dec 2011
    Location
    VA
    Posts
    397
    Rides
    Tex,
    My biggest concern with adding them myself is balance. Wouldn't that throw them out of balance? Also, being ignorant of how they're attached, would it be possible to attach them so that they stand up to the higher RPM's? I would even be OK with one of the billet flywheel suppliers attaching them for me and re-balancing the flywheel, if they're willing to do that (obviously at an additional cost). I am just not sure any of the suppliers would do that.
    Paul
  9. #19
    Junior Member
    Join Date
    Oct 2012
    Location
    carrabelle fl. 32322
    Posts
    Rides
    i just got the 212 cc predator, wondering how to connect the throttle cable, im a new guy to minibikes and have been looking for 1 for a long time to use for a pit bike, thanks guys
  10. #20
    Senior Member
    Join Date
    Sep 2009
    Location
    Brookville, PA
    Posts
    2,750
    Rides
    @RMM,
    Paul
    We are both kinda right. I forgot they changed how they engines were rated. a gx390 used to be 13hp and a gx340 was 11 hp. I blame this on emissions.
Similar Threads
  1. 420cc Predator budget build
    By JimmyRigged in forum Honda / Clone / Predator Engines
    Last Post: 07-28-2012, 08:17 PM
  2. duromax 420cc
    By sohc50 in forum Honda / Clone / Predator Engines
    Last Post: 06-14-2012, 03:04 AM
  3. Predator 420cc 20-25hp
    By iatemeself in forum Honda / Clone / Predator Engines
    Last Post: 05-02-2012, 02:00 AM
  4. Lifan 420cc
    By INTHE10s in forum Honda / Clone / Predator Engines
    Last Post: 12-21-2011, 06:29 PM
  5. predator 420cc how quick
    By proturbo in forum Honda / Clone / Predator Engines
    Last Post: 08-26-2011, 09:51 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
