Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Senior Member gasser's Avatar
    Join Date
    Mar 2010
    Location
    portland OR
    Posts
    117
    Rides
    Predator 79cc ??
    Anyone using the predator 79cc engine? Im building a mini trike and need an engine that doesnt take up much space. I prefer the look of the flathead engines, but I cant deny the small size and how cheap the predator can be had.
    Whats the word on these little guys?
  2. #2
    Join Date
    Mar 2010
    Location
    portland OR
    Posts
    117
    Rides
    Anyone? Bummer..
  3. #3
    Senior Member tomanator's Avatar
    Join Date
    May 2010
    Location
    west end
    Posts
    379
    Rides
    dont have one but ive have heard their under powered and clutches dont always fit do to shaft being wrong size
  4. #4
    Senior Member Spooker's Avatar
    Join Date
    Sep 2012
    Location
    SW Ohio
    Posts
    106
    Rides
    I've been playing with one on a test bench for a couple of weeks now. Out of the box they lack in throttle response and are hard starting when warm (even with a little choke). I installed a free-breathing filter element, modified a clone header using a die grinder to the bolt holes and header port, and ground the flange to clear the motors fins. Enlarged the jet just slightly and ..wow. Throttle response is snappy..it roars even with governor intact. Hot starts at half choke are one pull affairs. The shaft is 16mm, so 5/8 clutches won't fit unless you "sand" the shaft down. (YOUTUBE videos show this) I bought a 16mm clutch from OMB. My bike isn't done yet so this is as much as I can tell ya. Remember, it's 79cc..........spooker
  5. #5
    Join Date
    Mar 2010
    Location
    portland OR
    Posts
    117
    Rides
    Thanks for the info! Wouldn't it be easier to just bore the clutch out to 16mm instead of grinding down the shaft? Just a thought.
  6. #6
    Why not find someone selling a new 97cc Doddle bug engine that is all ready to use?
  7. #7
    Senior Member Stangrcr1's Avatar
    Join Date
    Sep 2012
    Location
    Marysville, WA
    Posts
    4,602
    Rides
    Gasser, buy me a case of beer and I will give you a running 97cc DB motor, with a clutch. You are only about 230 miles south of me. I might even meet you part way...
    Problem with boring the clutch is most clutches have the key machined into them, and boring will remove the shaft key.
  8. #8
    Join Date
    Mar 2010
    Location
    portland OR
    Posts
    117
    Rides
    That would be awesome. I've actually been meaning to head north to visit some friends. I might have to take you up on that offer!
  9. #9
    Member
    Join Date
    Apr 2012
    Location
    connecticut
    Posts
    Rides
    Quote Originally Posted by Spooker View Post
    I have this same engine, and while they seem to have worked out the shaft size issue, it is still hard to start hot or cold....how's the compression supposed to feel with a slow pull on the rope? It seems to pull through the compression stroke too easily so I wonder if the valves are properly adjusted. Can you post the details of the jet enlargement procedure? Thanks!
  10. #10
    Senior Member
    Join Date
    Apr 2011
    Location
    Dallas, TX
    Posts
    680
    Rides
    Hello driggs,
    These engines turn over easy because there is a compression release mechanism on the cam (pretty sure it has one). They are hard too start because they are set-up too lean (EPA rules). I don't have one, but think a good runner would be about the same or better than DB30 97cc, cause it's OHV vs flathead.
Similar Threads
  1. 7k Predator
    By iatemeself in forum Honda / Clone / Predator Engines
    Last Post: 10-06-2012, 11:09 AM
  2. 79cc Greyhound Carb Diagram
    By Timmahhhhh in forum Honda / Clone / Predator Engines
    Last Post: 09-14-2012, 09:10 PM
  3. New predator
    By travis123321 in forum Engines and Modifications
    Last Post: 08-19-2012, 10:01 PM
  4. Predator 420 Q?
    By paul_probus in forum Honda / Clone / Predator Engines
    Last Post: 03-28-2012, 11:36 PM
  5. 97cc DB30 vs. HF 79cc OHV
    By zettairyouiki03 in forum Engines and Modifications
    Last Post: 09-17-2011, 02:19 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
