Results 1 to 10 of 10
  1. #1
    Junior Member
    Join Date
    Jul 2013
    Location
    Belpre OH
    Posts
    Rides
    Talking Predator 212cc flywheel
    I'm looking into modding my predator 212cc engine with exhaust, air filter, fuel pump, etc. the first thing I was going to do was remove the governor. I know
    I have to get new valve springs, and I read you should get an aluminum flywheel to make sure your engine doesn't blow up. Do they make these flywheels? I've seen them for several other engines, but not the predator. I've also seen forums for this question, but they were pretty old. Thanks for the help!
  2. #2
    Junior Member
    Join Date
    Jul 2013
    Location
    Belpre OH
    Posts
    Rides
    Thanks soo much. If a use this flywheel and rod will it be safe?
  3. #3
    Member
    Join Date
    Jun 2013
    Location
    Bakersfield, CA
    Posts
    Rides
    It can still blow but it would take much more for it to happen from what I understand.
  4. #4
    Senior Member scootercat's Avatar
    Join Date
    May 2011
    Location
    Willow Run MI.
    Posts
    957
    Rides
    Is this Predator new? or an older model?....A.R.C flywheel will not fit the new "Hemi" head version,the crank has a different taper than the older engines have,I don't know about the A.R.C. rod,it might but You must check the rod journal dia. to be sure....Scootercat....
  5. #5
    Junior Member
    Join Date
    Jul 2013
    Location
    Belpre OH
    Posts
    Rides
    It's the new model
  6. #6
    Join Date
    May 2011
    Location
    Willow Run MI.
    Posts
    957
    Rides
    I don't know all about the difference from old to new,but I read something on "Bobs fourstroke" go-kart site about the different taper that is what the flywheel mounts on,and the A.R.C. 6652 wont fit the new model....
  7. #7
    Junior Member
    Join Date
    Jul 2013
    Location
    Belpre OH
    Posts
    Rides
    Do you know if any of them will?
  8. #8
    Senior Member
    Join Date
    Aug 2012
    Location
    Henry VA
    Posts
    398
    Rides
    The new model "hemi" head predator uses this:
    6626 ARC Kohler CH270/New Predator 212 Billet Flywheel
  9. #9
    Junior Member
    Join Date
    Jul 2013
    Location
    Belpre OH
    Posts
    Rides
    Sweet thanks youngengines, but will the rod still work with the new predator?
  10. #10
    Senior Member
    Join Date
    Aug 2012
    Location
    Henry VA
    Posts
    398
    Rides
    Quote Originally Posted by Al132 View Post
    Yes, same rod for old and new predators.
Similar Threads
  1. HF predator 212cc NIB $90 LPU
    By Cornishrooster in forum Mini Bike Parts
    Last Post: 07-11-2013, 05:26 PM
  2. Predator 212cc
    By bassplunker in forum Honda / Clone / Predator Engines
    Last Post: 05-07-2013, 10:23 PM
  3. Predator 212cc oil
    By Marlon77 in forum Engines and Modifications
    Last Post: 09-27-2012, 03:03 AM
  4. hf predator 212cc for $99
    By xmasmini in forum Honda / Clone / Predator Engines
    Last Post: 06-30-2012, 12:22 AM
  5. flywheel stuck on new 212cc predator
    By iatemeself in forum Honda / Clone / Predator Engines
    Last Post: 04-01-2012, 04:23 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
