Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Senior Member SnakePliscan's Avatar
    Join Date
    Feb 2014
    Location
    Nanaimo Bc Canada v9x1v5
    Posts
    177
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Predator hemi piston in non hemi block ?
    Predator hemi piston in non hemi block, will the flat top from a hemi go in a earlyer block ?
    Aare they the same compression height? Pin size ? diameters ? ring widths ?etc...everything but the dish man!
    Anybody know?
    Iim hoping i can swap one in while i swap to a gx160 head.......
  2. #2
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    2,460
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    You can bore size is the same but compression height is shorter. Most use it with .020 longer arc rod. You need to check it before ordering rod.
    Ole
  3. #3
    Join Date
    Feb 2014
    Location
    Posts
    177
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    hemi piston and rod
    Quote Originally Posted by ole4 View Post
    So that means the Hemi piston and rod will swap as an assembly.
  4. #4
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    2,460
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hemi rod is the same as the other preadtor rods so yes .
    Ole
  5. #5
    Join Date
    Feb 2014
    Location
    Posts
    177
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    hemi flattop piston
    So the compression height is less than a dish piston, 0.020" apparantly. also the rings are thinner and the piston is 12 grams or so lighter.
    So if your going to a gx160 head, which is a big time quench head, your better off with the higher dish piston.
    Makes ya wonder if the only reason the hemi got a flattop is because it was cheaper to produce.
  6. #6
    ole4's Avatar
    Join Date
    Nov 2007
    Location
    Georgetown TX
    Posts
    2,460
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    It works well if you are going to use the +.020 ARC billet rod. Othewrwise not so much. However anytime you reduce reciprocating weight it helps reduce vibration. So for that it would be a plus.
    Ole
Similar Threads
  1. 212 Predator non-hemi Flattop piston install?
    By Sundance customs in forum Honda / Clone / Predator
    Last Post: 08-17-2014, 05:11 PM
  2. Hemi flattop piston swap
    By Jrdragbike in forum Honda / Clone / Predator
    Last Post: 08-05-2014, 09:39 PM
  3. Predator Hemi vs. non-Hemi
    By Street Smart in forum Honda / Clone / Predator
    Last Post: 07-20-2014, 02:06 PM
  4. Hemi Cylinder Head and Piston/rod, new take off, So Cal
    By LSCustoms in forum Mini Bike Parts
    Last Post: 05-13-2014, 02:15 AM
  5. Predator Hemi vs Non Hemi head
    By Ratbike in forum Honda / Clone / Predator
    Last Post: 12-29-2013, 06:45 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
