Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 147
  1. #1
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,954
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Hemi Head Predator Build (60363)
    Hello members of this great forum and welcome to this build thread. I would be glad to listen to any Ideas on this build ...so fill free to chime in. Oh and this is not a big engine build thats going to make your mini bike pop wheelies for a hundred feet...but wouldn't that be fun.
    This is the 212 Predator (60363) engine that I'm going to use.
    This build is going to be more of a torque build than a high rpm build. So this is some of the parts for this build :Air filter adapter and high flow air filter (K&N Style)
    OMB 140 e-tube and jet kit.
    Lil Indian, Ruttman, DB30, Warrior, lil Bill, EZ Rider, Savage SSC , Powell
  2. #2
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,954
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Black Mamba (junior) cam from Tim Isky. 274 lift @ 230 duration.
    26# springs.
    Arc billet flywheel (with 32 degrees of timing built in)
    I'll be posting more parts as I get them. Also I'm going to cc this engine before its tore down, and after its built... and will be checking stock timing with a timing light and a degree wheel. (before and after build )
  3. #3
    Senior Member
    Join Date
    Aug 2012
    Location
    Henry VA
    Posts
    399
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Good luck on your build!
  4. #4
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,954
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks Barry, glad to see ya on !
  5. #5
    Senior Member Street Smart's Avatar
    Join Date
    Jul 2010
    Location
    Brooklyn, NY
    Posts
    1,175
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I`m in for the ride, lol.
  6. #6
    Senior Member jdblood202's Avatar
    Join Date
    Jul 2014
    Location
    Virginia
    Posts
    238
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Good luck! You going with a different rod while you're at it?
  7. #7
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,954
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Rod is ordered, valve spring retainers with positive split keepers and stainless valves.
  8. #8
    Senior Member
    Join Date
    May 2014
    Location
    Iowa
    Posts
    159
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Are you using the Hemi head? Will the 26# springs work with the Hemi head?
  9. #9
    Sho-nuff minibikin''s Avatar
    Join Date
    Aug 2007
    Location
    Pennsburg, PA 18073
    Posts
    7,950
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Cuda54 View Post
    Yes the 26's will work on the hemi. You still need to check for coil bind with your camshaft,
    Bye Felicia!
  10. #10
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,954
    Mentioned
    12 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Yes this is a hemi head engine, and I'm going to use the original head. Valves are going to be stainless 27mm Int. and 25mm Exh. with 26# springs.
    I did a quick check on the lift of the stock cam while still in the engine with a dial indicator ...and the lift was down and surprised me. I don't have my notes in front of me but it was something like 221 Int. and 219 Exh. so I will be checking for (spring) coil bind with the 274 lift Isky cam.
Similar Threads
  1. Hemi predator head start
    By vwfan79 in forum Mini Bike Parts
    Last Post: 07-04-2014, 09:14 PM
  2. predator 212 hemi head 60+ mph
    By britt vanegas in forum Honda / Clone / Predator
    Last Post: 05-18-2014, 12:54 AM
  3. Predator Hemi vs Non Hemi head
    By Ratbike in forum Honda / Clone / Predator
    Last Post: 12-29-2013, 06:45 PM
  4. New Hemi Predator Engine Take off parts, model 60363, So Cal
    By LSCustoms in forum Mini Bike Parts
    Last Post: 11-22-2013, 11:19 PM
  5. New predator head hemi WHERE TO GET?
    By Predator212Laxer in forum Honda / Clone / Predator
    Last Post: 07-08-2013, 11:31 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
