Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 6 of 6
  1. #1
    Senior Member yalipito's Avatar
    Join Date
    Feb 2011
    Location
    georgia
    Posts
    411
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Predator 60363 or 69730, why?
    Well guys, I need your help choosing a predator since my briggs blew up today. Which of the two is better and why? It will remain stock for now. Thanks
  2. #2
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,563
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
    60363 Hemi head engine, hemi head design with cantered valves, 27mm int. valve 25mm exh. valve...flat top piston and the 60363 engine will except all the honda gx200 and clone cams.
    Lil Indian, Ruttman, DB30, Warrior, lil Bill, EZ Rider, Savage SSC , Powell
  3. #3
    Join Date
    Feb 2011
    Location
    georgia
    Posts
    411
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks again OND.
  4. #4
    OND's Avatar
    Join Date
    Apr 2014
    Location
    Area 51 S.C Ky.
    Posts
    9,563
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Rides
  5. #5
    Senior Member
    Join Date
    Oct 2013
    Location
    Canada
    Posts
    318
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    I like the non Hemi myself...
    Seems the Hemi blocks split way too easy...
    The non Hemi also comes with 27/25 valves, in stock form the RTC 6,8 and 9 heads flow better... In stock form!!!
    You can use a clone cam in a non Hemi without issue...
    The non Hemi cam is .004 larger in circumference... The factory service limits are well above this...
    I like using a Honda crank, Hemi flat top piston and Honda 3.403 long Rod... Makes for .005-.008 pop up and use a .045 gasket...
    Throw a dyno 308 cam in with 1.2 rockers, and dual springs feed it alky with a gx390 carb, and hold on...
  6. #6
    Join Date
    Feb 2011
    Location
    georgia
    Posts
    411
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Prowler08 View Post
    Thanks for the ideas. I did buy the hemi and for now it will remain stock but I would like to gain some power without opening the engine, it is used in a converted electric to gas golf cart the my son was given.
Similar Threads
  1. Hemi Head Predator Build (60363)
    By OND in forum Honda / Clone / Predator
    Last Post: 09-10-2016, 10:13 PM
  2. 69730 Stock 27mm/25mm head
    By LSCustoms in forum Honda / Clone / Predator
    Last Post: 05-10-2015, 08:15 PM
  3. predator 60363
    By Buck Sharp in forum Engines and Modifications
    Last Post: 07-10-2014, 02:28 PM
  4. New Hemi Predator Engine Take off parts, model 60363, So Cal
    By LSCustoms in forum Mini Bike Parts
    Last Post: 11-22-2013, 11:19 PM
  5. Baja with Predator can I use lighting coil pack on Predator?
    By JoePapa in forum Mini Bike Discussion
    Last Post: 12-01-2012, 04:16 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
