Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 10 of 10
  1. #1
    Junior Member pmoat's Avatar
    Join Date
    Nov 2010
    Location
    New Jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Stock Spring Specs on 6.5 Clone?
    I'm putting in 18 lb valve springs on my HF 6.5 clone but was curious as to what the stock spring force is. Anybody know?
    Thanks!
  2. #2
    Senior Member Leftythenub's Avatar
    Join Date
    Oct 2010
    Location
    St. Louis, MO, USA
    Posts
    242
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by pmoat View Post
    Thanks!
    It's somewhere around 10 lbs.
  3. #3
    Senior Member vette66_00's Avatar
    Join Date
    Apr 2009
    Location
    Fresno, Ca
    Posts
    2,485
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    As Lefty said around 10 lbs... But we have test a few sets at 8lbs up to 13lbs and of course both springs are not equal tension, Usually 1 to 2 lbs off.
  4. #4
    Join Date
    Nov 2010
    Location
    New Jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks for the responses!
    Do you agree that 18# is the way to go with a de-governered, pretty stock engine with the billet flywheel, header with muffler, and hi flo air filter?
  5. #5
    Snake Poop Strigoi's Avatar
    Join Date
    Mar 2008
    Location
    Martinez, CA
    Posts
    10,065
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    you'll be fine with 18lb springs.
    it'd be a good idea to get a billet rod too since you removed (bypassed?) the gov. if you only bypassed it, you have to remove it anyways to install the rod.
  6. #6
    Join Date
    Nov 2010
    Location
    New Jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by Strigoi View Post
    Took the gov. out Strigoi. Definitely going to put the billet rod in also.
  7. #7
    Senior Member
    Join Date
    Jul 2009
    Location
    Southeastern PA
    Posts
    4,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Don't forget to rejet or drill out the stock jet
  8. #8
    Join Date
    Nov 2010
    Location
    New Jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Quote Originally Posted by C9H13NO3 View Post
    I see that you've done some nice work on your engine. Can you recommend what to drill the jet out to? I know there's a process to go through involving running the kart, pulling the plug, and checking it to determine if jet size is right but is there a basic size that will work well?
    PS I had to look up your username...adrenaline!
  9. #9
    cjtmini's Avatar
    Join Date
    Feb 2008
    Location
    westland mi.
    Posts
    563
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    drill the main out with a #65 (.035") drill this will give you a #90 jet. I also drill my slow/idle jet with a #77 drill. This reduces the deceleration popping and easier cold starts
  10. #10
    Join Date
    Nov 2010
    Location
    New Jersey
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Thanks cjtmini
Similar Threads
  1. Honda/Clone 5.5 and 6.5 hp Bolt size and torque specs
    By vette66_00 in forum Honda / Clone / Predator
    Last Post: 07-13-2016, 09:30 PM
  2. stock 6.5 hp clone
    By waynelass in forum Honda / Clone / Predator
    Last Post: 12-05-2009, 07:53 PM
  3. Stock 6.5 clone
    By BraveHeart. in forum Honda / Clone / Predator
    Last Post: 08-02-2009, 02:24 PM
  4. 6.5 clone specs ??
    By doubletrouble in forum Honda / Clone / Predator
    Last Post: 05-26-2009, 07:58 PM
  5. Clone gov to carb connecting rod and spring needed.
    By deezildennis in forum WANTED
    Last Post: 05-26-2009, 08:27 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
