Follow us on...
User Tag List
Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    Junior Member
    Join Date
    Apr 2011
    Location
    north carolina
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    How do i install this kill switch into my 6.5hp harbor freight engine?
  2. #2
    Senior Member mmisterbungl's Avatar
    Join Date
    May 2010
    Location
    Alice, TX
    Posts
    8,676
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    well hello to you too!!!
    Welcome to OMB.
    Try the search function up top for the phrase "kill switch". In the meantime, heres' some reading material.
    http://www.oldminibikes.com/forum/ho...ll-switch.html
  3. #3
    Senior Member The Restore Kid's Avatar
    Join Date
    Jul 2007
    Location
    Michigan
    Posts
    11,695
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Somewhere there should be a wire that connects to the ignition coil, then runs out to the open area where all the wiring is.. When THAT wire is grounded out, it kills the spark.. so find your original shut off switch, and just attach the wire from your new switch, to the old switch, or into that coil wire some where.. If you look at the system you should be able to figure out how it's all working... When the switch is turned on, there is NO CONTINUITY so the engine runs.. shut the switch off it makes contact and grounds out your spark... You just need to figure out what wire you are grounding to kill the engine.. it should be half hidden under your blower cover somewhere..
  4. #4
    Member creekflea's Avatar
    Join Date
    Apr 2011
    Location
    Bayville, NJ
    Posts
    59
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rides
    Run one wire from the coil to your left handgrip, and leave about 3" bare wire. Next you'll need to run another wire to a ground, (like a motor-mount or something) than up to your right handgrip, leaving another 3" of bare wire. When you want to stop the motor, grip both wires firmly and motor will shut off. its a great "invisible" kill switch that all the cool kids are doing these days!!
    Now that Ive wasted everyones time and posting space...please refer to above replies!
    Thank you
Similar Threads
  1. what do i need and how to install 6.5 harbor freight motor
    By legna in forum Mini Bike Discussion
    Last Post: 03-21-2011, 09:26 AM
  2. how do i hook up a kill switch to a B@S engine?
    By azndude3141 in forum Engines and Modifications
    Last Post: 04-06-2010, 04:30 AM
  3. Kill Switch install
    By timinator in forum Briggs & Stratton
    Last Post: 07-11-2009, 08:06 AM
  4. Harbor Freight Engine
    By ohman11 in forum Mini Bike Discussion
    Last Post: 08-24-2008, 04:00 AM
  5. harbor freight clone install
    By superior in forum Honda / Clone / Predator
    Last Post: 04-25-2008, 08:18 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
